anyone know anything about ford...minivans? haha.
Rep Power: 0 anyone know anything about ford...minivans? haha.
So despite being a honda fan.. my parents have this dreaded 2002 ford windstar.. which we have owned since new and haven't really had any trouble until now.
Yesterday, the van would not start, my dad attempted to boost it since the battery was weak. but no luck. the engine wouldn't even turn over. So he replaced the battery, and it still wouldn't turn over. My dad then removed and tested the starter, and it functions fine. put it back on and flicked the key and it still wont turn over... After getting underneath the van and crossing connections on the starter with the key turned forward in the ignition, the engine would crank.. but wont start. I really have no clue what it could be. maybe a relay issue or something to do with the fuel pump? or maybe security system? im at a loss.. i know my way around my car.. but a van. no way. But would anyone here have any idea?.. i've posted this on other forums with no luck. Thanks in advance.
Mark
Mark
Trance Addict
Re: anyone know anything about ford...minivans? haha.
+1. It's easier, and more than likely, cheaper to troubleshoot first before you start throwing money at a problem. You don't wanna replace a 300 dollar part and come to find out a 25 cent piece was the cause of the problem in the first place.
Rep Power: 0 Re: anyone know anything about ford...minivans? haha.
im not 100% sure cuz i haven't looked at it myself yet. but my brother said that there was no spark and my father said he couldn't hear the fuel pump.. again im not exactly sure, im gonna check it out myself after i get off work tomorrow.
Rep Power: 191 Re: anyone know anything about ford...minivans? haha.
if ur not getting fuel id check the inertia switch first.. if the red button is up then ur not getting any power to the fuel pump. gets push the button down and see if it starts. the switch would be in the trunk somewhere.
1 Post
Rep Power: 364 Re: anyone know anything about ford...minivans? haha.
Ford... wow, maybe try a ford forum?
When you first put the key in you should hear the fuel pump before it actually starts. Check the spark plugs yet? Those would rule out your spark part of the equation, they are cheap and probably should be replaced anyways.
If it's not there its underneath the dashboard on the passenger side. It can sometimes trip if you bump a parking barrier hard enough or whatever.
I have posted this on a few ford forums.. most responses were to get rid of the van cuz they were junk. which i do agree but again its not my vehicle, and its a hard job to get rid of something that don't run... even if it did run its still not worth much.
My uncle took a multimeter the other day and checked all the fuses, relays inside the van etc etc... power is going to the starter. but again flick the key, nothing. cross connections manually on the starter and the engine will turn over.. no spark or fuel pump kicking in. Could it be the crank positioning sensor or possibly another relay somewhere?
Rep Power: 209 Re: anyone know anything about ford...minivans? haha.
Well i have a 2000 ford minivan and it never gave me these kinds of problems...When i got it though it had been through a wreck and the inertia switch was tripped and it didnt start but after i reset the inertia switch, it works fine now. I would look at that just to rule that problem out, its located in the back on the right side....good luck
well.. a update. we replaced the crank sensor. van started and worked perfect. they took it for a couple hours drive yesterday.. and now its back in the driveway this morning with the same issue... whats going on??
