1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
long crank, trouble shot but still persistant
Old Feb 4, 2011
laack's Avatar
laack is an unknown quantity at this point
My brother pulled his civic (94 cx 106,000) out of storage after studying abroad for the last 1.5 years. i just replaced the timing belt, tensioner, water pump, drain/refill all fluids, adjusted valve lash, new plugs, fuel filter, pcv, new gas and finally adjusted ignition timing.
the issue behind it is it cranks for an excessive amount of time before firing. however, if i crank it for a "rev" or 2 then turn ignition off and then turn the key back to start it will fire right up. for what ever reason the engine just needs to turn over once turn off ignition and let the pump reprime and it will fire on the first (of second attempts) turn.
what could cause the need to turn the engine, re prime and result in an immediate engine start? the battery tests strong. I haven't replaced the distributor cap or rotor due to the fact that im throwing his money down the drain, even though it was due for all of it as just scheduled mx.
I also haven't done a compression test to rule out engine issues. Should i do this first before working on anything else? He hasn't had it on the highway yet either or long drives since its been pulled out of storage.
Old Feb 4, 2011
StaticFire450's Avatar
Bringer Des Blutes
StaticFire450 is an unknown quantity at this point
Re: long crank, trouble shot but still persistant
I would try a new ECU or Distributor. Not go buy one, but plug someone elses up real quick. diagnose what the prob is.
..Perhaps its something random. Fuel filter.. Injectors.. Any CEL? Perhaps the idle air control valve. may be bad. My old Honda use to not start on First try & that was bad(IAC)
Old Feb 5, 2011
laack's Avatar
I dont have a spare civic to take parts off at the moment, no CEL and fuel filter is new. IACV is freshly cleaned and long crank persists. Im just going to have him run a few tanks of injector cleaner through and see if that helps.
Old Feb 7, 2011
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
there is a service bulletin on this. Have you checked anything in regards to the fuel pump?
Old Feb 8, 2011
MartinL's Avatar
MartinL will become famous soon enoughMartinL will become famous soon enough
laack, I took my dad's old 91 civic last summer. The car had been sitting outside for 3 years not a single start or anything done to it. I had all my fluids changed, new air and fuel filter, and installed new plugs. For the first little while I had to hold the key for about 8 seconds before car would start. I don't have any issues now on it now but at the time if it didn't want to start after 5-8 seconds I just stopped and re tried and like you said, started without a problem. I tried that seafoam stuff to clear up anything inside the engine and that also helped a bit. 1.5 years in a garage is cozy
heath3000
Jun 27, 2015 10:30 PM
Markwnjr
Turbo
Jun 25, 2015 06:36 PM
jordan1794
Jun 8, 2015 08:37 PM
jackoncruzpr
May 24, 2015 12:24 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
