Help!! Won't go over 4k
Rep Power: 0 Help!! Won't go over 4k
I have a 2000 Civic Hx. Was driving fine until I floored it. Started to sputter and won't rev over 4000 rpm. When I let it sit it'll run fine and go over until I reach 5-6k then it'll sputter and not go over 4000 rpm again. I have no check engine light. I cleaned the vtec screen in the solenoid. It just will not work. It's completely stock d16y5 engine except the cold air intake. Please help!
Received 1,144 Likes
Rep Power: 485 Re: Help!! Won't go over 4k
Check engine light? Highly likely you do. Find the code and report back
edit: clearly I can't read. You said no check engine light. There could be the slim chance the CEL bulb is burnt out, however
If CEL bulb doesn't work you ought to fix that. It may be ugly but it's damn handy.
It's supposed to turn on for a short while when you turn the key on before you start the engine.
Received 1,440 Likes
Rep Power: 338 Thread
shadeymac
02-26-2014 07:17 AM
leandro1.8
12-02-2010 02:33 PM
Tennessee Mike
08-08-2010 11:36 PM
