1994 civic d16z6 leaking coolant
Old 12-10-2017
KyleCivic's Avatar
KyleCivic is an unknown quantity at this point
Hey guys! I’m pretty new to the civic scene, just bought a 1994 civic ex and I replaced the head gasket and basically all of the coolant hoses and heater hoses. Just got done putting everything together and filled it up with coolant and it starts to leak from the bypass hose on the passenger side of the intake manifold. At first I thought the intake wasn’t on all the way so I tightened it down and it slows the leak down a bit but it’s still there. Not sure if it’s the gasket, cracked manifold or what. Thanks for your answers!
Old 12-10-2017
Re: 1994 civic d16z6 leaking coolant
You may need to take it back apart to inspect your work.
Assuming you actually replaced necessary gaskets, maybe a chunk of the old intake gasket didn't get removed completely, now the new one can't seal because the surfaces aren't flat.
Old 12-11-2017
KyleCivic's Avatar
Yeah you definitely hit the money on that lol. Big chunk of the old gasket right under the coolant passage. Thanks man! I appreciate it!
Bman2212
09-02-2015 11:49 AM
medicpg
01-12-2015 07:47 PM
eswar_ner
10-08-2014 06:12 PM
satown210
03-02-2011 05:46 AM
littlemanx23
02-19-2009 01:38 PM
Quick Reply: 1994 civic d16z6 leaking coolant
