Rough idle with ac on at stop/park - Honda Civic Forum
Old 08-07-2018
Bonexwb is an unknown quantity at this point
lately ive been having a rough idle at a stop with my ac on. It makes a clicking sound And idle. Check the freon, but pressure says i still have a lot in it. Ac blows cool air at low. But warm air when high. I just replace my compressor two months ago.
https://m.imgur.com/gallery/vLOJAcJ
Bonexwb is offline
Old 08-07-2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: Rough idle with ac on at stop/park
if it is rougher than you'd expect, common problems are the radiator fan not coming on, or too much refrigerant in the system. too much juice in the lines makes it blow warmer than the right amount.
a lot of home-ac repair people just over fill it. a free gauge on a $16 can is not accurate. i repair everything i can at home, but when it comes to filling AC, i have a shop vacuum moisture out of the system and refill it with good equipment. if you filled it at home, you might consider having someone with better equipment redo it.
you have a lot of missing info here, like who did the repairs, it there oil in the compressor, what type of car, manual or automatic, is it filled with r134a or some weird leak stop blend, etc.
RobertD is offline
Old 08-07-2018
Probably far too much freon in the system. It's soooo easy to overcharge these small systems.
Get a pressure gauge for the high side, you'll probably see it go far beyond 400 PSI when it starts cutting out.
EDIT: Make sure the condenser fan is actually running first.
ezone is offline
Cool_Man
31
06-20-2017 06:29 AM
Schurch1990
10-13-2016 10:31 AM
crowtoo
05-11-2015 07:50 PM
riceburner254
05-09-2013 02:08 PM
boostnm3
Buy, Sell, & Trade
12-22-2009 11:57 PM
Quick Reply: Rough idle with ac on at stop/park
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
