2000 Honda Civic GX exhaust problems, need help.
Old Aug 21, 2015
Anubis1337's Avatar
Anubis1337 is an unknown quantity at this point
I have a 2000 Honda Civic GX and I am getting several error messages.
cylinder 1 misfire
Multiple cylinder misfires
low o2 voltage
Catalytic system below threshold
I have replaced the spark plugs and spark plug wires. I have also cleaned the throttle body as well as replacing one of the o2 sensors. I am at the end of knowing how to find the problem. The next thing is replacing the Catalytic converter. Any help would be much appreciated. Thanks.
Old Aug 21, 2015
Re: 2000 Honda Civic GX exhaust problems, need help.
Do NOT replace the cat yet.
Misfires can kill even a brand new cat in a very short time. Sometimes mere minutes if it runs bad enough.
Fix all running problems first, then see if the cat code still returns after driving it.
Compression test?
Valve adjustment?
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
liljoe
Nov 4, 2001 01:27 PM
