Rpm when is Idling
Old Aug 26, 2017
compu2's Avatar
compu2 is an unknown quantity at this point
Rpm when is Idling
I have a honda civic 00 LX , my question is How Many Rpm's Should my Car Be When It's Idle?
Old Aug 26, 2017
Re: Rpm when is Idling
Depending on engine type, trans type, and your country, somewhere between 650 and 750 RPM (using a scanner or digital tach, not the tach needle on the dash)
Old Aug 29, 2017
compu2's Avatar
Ok thanks ,
For a honda civic 00 LX , please Can you tell me how to check the dwell and rpm with a digital tach ?
note: my digtal tach have the option for dwell
Thank you sir.
Old Aug 29, 2017
Originally Posted by compu2
Ok thanks ,
Thank you sir.
How? Refer to your user manual.
RPM is the setting on your meter you need to use.
Dwell will give you no useful information. The only time I ever need to use dwell is when diagnosing a 'no spark' situation.
The "tach test" wire should be blue and located close to here (pic)
Old Aug 29, 2017
compu2's Avatar
Ok thanks
but Sir I am using a LCD AUTOMOTICE MULTIMETER WITH TACHOMETER KIT. Do you know what I am talking about ? is a multi-meters for cars.
Old Aug 29, 2017
Doesn't matter what meter you use.
The car was equipped with that single wire as a designated test point.
You will have to read your instructions to figure out how to make use of it.
And again: Ignore dwell readings taken from an engine that runs. There will be numbers that can be read if you use that setting, but they are of no value to you.
