Quick question
Old 05-16-2013
scorpionsinz's Avatar
scorpionsinz is an unknown quantity at this point
Quick question
Just swapped out my trans on my 01 EX. Still have the stock radiator. With the new trans they sent an inline filter. Problem i have is im unsure which line is the return line. Is it the left or right line on the radiator? They are both on the bottom of the radiator. In other words which line is the return line off the trans? The front one or the back one by the rear trans mount closer to the dipstick?
Ive looked everywhere for a reference and cant find one. Any help would be great. Thanks in advance.
Old 05-16-2013
Re: Quick question
When I get a factory reman trans, they send a filter KIT with pipes and brackets and stuff to install it along the bottom of the radiator fan shrouds.
They install it in the line that comes from the drivers side of the radiator. So the drivers side of the radiator is the return......as long as you didn't get the rubber lines swapped at the trans LOL.
Old 05-16-2013
Dr Krieger of Modification
mac25's Avatar
Re: Quick question
isnt it a looping system sending the transmission fluid through the rad and back into the transmission? if it's all one loop couldn't it go anywhere to filter?
Old 05-16-2013
Re: Quick question
No. When a trans blows up, the trans cooler can catch and hold a lot of debris from the failed trans.
If trapped debris comes out of the cooler later on, it can trash your new trans. No warranty on a failure if that happens.
The filter is installed to stop that trash from entering the new transmission if (when) it comes out of the cooler.
CraigW
08-18-2015 07:06 AM
civic98?
08-13-2015 01:32 AM
Strycker
08-02-2015 08:40 PM
sam31444
ECU Fried
07-20-2015 08:31 AM
NoobyKid
07-13-2015 07:53 AM
Quick Reply: Quick question
