alternator removal
alternator removal
Hello folks, can anyone tell me if the 1999 civic alternator can be removed from under the hood, or is it removed from underneath. I had just replaced the timing belt, pump etc. and decided to removed the alternator, however the lower blot was frozen with rust. I had to remove the bracket as well. That could only be removed by pushing the engine ahead and dropping it down. Enlighten me please!
Super Moderator
Re: alternator removal
Are you SURE you want to remove it?
Looks like this (potentially high?) guy can barely remove it from the top, and that's if you can remove the bracket. Someone in the comments mentioned dropping it instead.
At about 37:40 this guy gets his out the bottom. Looks like an ordeal, for sure.
jzhartman
22
07-23-2015 10:42 PM
ballmich
07-09-2015 11:59 AM
