Won't go into 3rd gear
Old Jul 1, 2018
Shellbell's Avatar
Shellbell is an unknown quantity at this point
Question Won't go into 3rd gear
I'm new at this but I need to know why my 96 Honda Civic will not go into 3rd gear after the gears got slamed. Its a manual and and angry boyfriend trying to change gears.I was told that the gears could be bound up any help?? Thank you in advance for
Old Jul 1, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: Won't go into 3rd gear
Auto? Manual? Teenage son driver? Slamed?
Old Jul 1, 2018
Shellbell's Avatar
its a manual and a 96 angry boyfriend trued to change gears to fast and aggressive
Old Jul 2, 2018
Colin42's Avatar
Does it work if you double clutch it?
the syncro may have gotten trashed.
All the other gears work?
Old Jul 2, 2018
RobertD's Avatar
Does 4th work ok? You need to try to get it into 3rd at the trans side of the shift linkage. Maybe he just bent or broke something related to the shifter
In my experience replacing the trans is usually the way to go when I break something. Recommend finding a less angry boyfriend or one smart enough to fix what he breaks.
Old Jul 2, 2018
You might want to rethink some of your life choices. His anger management problems just cost you a transmission, and it's likely to cost you far more than just car repairs as his problem becomes your life
Trans probably will need to be rebuilt/repaired/replaced to fix it.
Old Jul 4, 2018
Wankenstein's Avatar
OP...this could be your future:
thefatalepic
Transmission
Mar 13, 2015 03:02 AM
EP3Love
Jul 23, 2011 03:57 AM
SatinSilver03
Dec 3, 2009 08:09 PM
3stripes
Jul 11, 2004 03:17 PM
JonathanMoxon
Jul 25, 2002 06:17 PM
