PDA
View Full Version : Engine
Pages : [1] 2 3
  1. Intermittent No Start
  2. Workshop Manuals?
  3. Vtec solenoid question
  4. P0420
  5. Key will not turn over in switch to start!
  6. 0 compression all 4 cylinders
  7. Throttle Response is Sluggish
  8. Po128
  9. 2006 Accessory Belt Tensioner Bolt Broken
  10. Engine lost Its power
  11. P0420 burning oil - can still drive
  12. acceleration issue???
  13. Radiator
  14. 2008 Honda Civic rattling noise.
  15. Check engine light auto-reset
  16. Sistema de enfriamiento del motor
  17. 2012 Honda Civic with difficulty starting
  18. Radiator fans
  19. Help!!! Fuel line
  20. Problem on acceleration 2013 Civic 1.8 l
  21. My hybrid is having a moment (advice lol)
  22. Help with identifying what this is and does
  23. Leaking part identification
  24. P1129 will not go away
  25. P0497 and p145c codes
  26. 2015 Honda Civic – Passenger Side Radiator Fan Not Turning On with A/C
  27. Fuel trims on acceleration and fuel pressure test adapter
  28. 2007 Honda Civic Alternator Part
  29. Broken radiator and more parts
  30. 2006 honda civic engine code P0848 keeps going into limp mode
  31. I smell gas/ chemical/ burn smell inside the car
  32. Raccoon damage
  33. Canister vent always off
  34. Spark Plugs & Valve Adjustment - 2013 Civic
  35. P0507 Idle High then...
  36. 2007 Civic Starter replacement now won't start
  37. IAC OR IACV - Civics 8th gen 2006 EX has it or not? P0507
  38. P0304 misfire ?
  39. Whining sound
  40. oil leak passenger side
  41. 2015 jerk and rpm fluctuating
  42. 8th gen civic EX/ noise from engine bay
  43. 2013 LX excessive vibration at idle / loud rumbling sound [solved]
  44. 06 Belt tensioner bolt Repair Question
  45. Replacement Screws/Clips for Front Engine Plate Cover 2015 Honda Civic?
  46. 07 civic SI power loss and VSA light
  47. Car starts but it takes a lot of cranks to get it going.
  48. Car won’t start
  49. Gas mileage is dropping.
  50. 08 no crank and no indicater on dash for prndl [solved]
  51. What Do the E-15-11 Ports on the Breather Pipe (17137-RRA-A00) Connect To?
  52. What is this part?!?
  53. 06 Civic Won't Stay Running and Only Starts Under Odd Condition
  54. Overheating-both hooses hot- loosing overflow coolant-heather works great
  55. Not starting and Vsa fault
  56. Throttle Body Torque Specs - Civic EX 2006 Coupe (solved)
  57. Lower block oil leak: help
  58. M.A.P. non-sensical SIZE
  59. Honda civic 8th gen sudden coolant leak (2010) [solved]
  60. P0507 - Throttle body, MAP, MAF sensors and EGR cleaned - HELP
  61. Throttle Body Cleaning Problems with High Idle
  62. Engine whining sound. [solved]
  63. Honda Civic 2012 1.8 L starter problem.
  64. 2014 Civic Sputter from exhaust/ 1500-2000rpm jerking
  65. 2014 Honda civic stalling [solved]
  66. Delayed start?
  67. Ignition Cylinder won't go back into housing
  68. Idle Correction - Covic 2006 EX coupe - 8th Gen
  69. 2011 Honda Civic FD 1.8 Coolant leak [solved]
  70. Throttle Body Cleaning (couldn't take the body out)
  71. Oil Line Leaking
  72. Leak on passenger side
  73. Starter Motor and Clutch question
  74. 2011 LX Oil Leak
  75. Require advise - under the hood
  76. oil cooler hoses question
  77. Oil Leak Source
  78. Fuel Injectors
  79. 2012 Civic LX Engine Mount Diagnosis
  80. 2012 Civic Weak Acceleration
  81. FTP (fuel tank pressure) Sensor location [solved]
  82. Failures and shakes in Honda Civic EXS 2009 AT
  83. Cooling fan running slow [solved]
  84. Calculated load value
  85. Check fuel cap message
  86. Pcv rattle
  87. EVAP Purge Valve
  88. 2006 civic engine mount upper torque rod stripped/stuck screw
  89. How to Troubleshoot ABS/VSA Codes on 2015 Civic Coupe EX: Need Advice!
  90. Help - battery to starter black wire
  91. Obd2 scanner
  92. Oil Leak on my 2012 Civic DX
  93. R18a - sensor identification
  94. Engine idle speed and Resonance
  95. Viscosity for 06 Civic
  96. check engine light p0497 & p145c
  97. 8th Gen Si Weird Acceleration Issue
  98. Is this dirtiness a sign that the PCV needs to be replaced?
  99. Intermitent rough idle
  100. installing a CAI
  101. 2014 Honda Civic LX Oil Change Question...
  102. Noise from 2.2 Diesel engin
  103. P2271
  104. NGK 95710 Spark Plugs Authenticity
  105. Catalytic convertor performance low
  106. check the engine emission system
  107. Cause of this mysterious white stuff?
  108. Civic Hybrid white smoke from exhaust
  109. 220k Civic 06 LX P0420 Scan Readings
  110. P1659 Civic 2013 Fixed
  111. IAT sensor values
  112. 2011 Si Troubleshooting engine failure
  113. 2006 chattering relay, not starting [solved]
  114. oil filter mount replace
  115. 2006 1.8L No Crank
  116. Vibration coming from engine
  117. SOLVED: Engine will not start
  118. Runs/ Drives then dies
  119. Civic Diesel DPF Warning failed regeneration - HELP!
  120. sputtering
  121. Remove fuses to do compression test? [solved]
  122. Civic 2014 EX Intake Manifold & Valve Cleaning
  123. System too lean
  124. 2012 Honda Civic Not Starting
  125. 2008 Civic EX - SLOW/NO START
  126. Pressure on cooling system
  127. Please help - 2.2 I-CTDI can't locate knock sensor
  128. 2006 Honda civic 1.8
  129. Check emmision light 2014 honda civic
  130. No start and hesitations
  131. How to read ECT2 sensor using ODB-II reader?
  132. Attempting to revive 2012 Si, ticking noise
  133. 9th Gen civic si Idle issue
  134. Cost of just labor to replace an alternator belt adjustment tensioner in my 2005 ciLX
  135. Engine fans not turning on!
  136. Spark Plug Installation. [solved]
  137. Swapped out engine on 2006 Civic, what can I do with old one?
  138. What is this racket P2646
  139. Strange scratching sound during start up
  140. 2015 Civic no start
  141. 207 Civic not starting/cranking - New starter fitted started once and not again
  142. Vibrations at idle
  143. motor mounts 2012 civic sedan
  144. Cold start after sitting all night
  145. Stutter on acceleration and VSA light comes on
  146. Please help- multiple warning lights on
  147. 2006 Civic, crank no start, no CEL, no codes
  148. 08 Civic Coupe auto stuck in limp mode
  149. 8th Gen Civic Broke Tensioner Adjuster Control
  150. vibration in reverse
  151. Oil leak
  152. Assessment of damage after overheating Honda Civic 2011
  153. Temperature lamp illuminating
  154. Problem idling:
  155. Honda's Manual says to use only original coolant - but it costs 3 times as much [pic]
  156. Fuel Injectors
  157. 2015 Sedan Wont start, then will and runs fine
  158. Idle RPM drops
  159. 2014 Honda Civic Cold Cranking Issues
  160. BIG ASS rattling in the cabin
  161. 2010 2.2 Diesel starting issues
  162. Seeing Coolant Level [solved]
  163. 2015 LX Clunk When Pressing Accelerator
  164. Runs for 2 seconds.
  165. 2007 Honda civic help pls?
  166. Rough Idle/No Start
  167. '12 1.8L Civic Difficult/Long Start Every Morning
  168. Need help what IS this piece called
  169. EGR Replace?
  170. 2009 Honda Civic Hybrid IMA "drain" oil
  171. 2007 civic oil pan replacement
  172. Coolant leak, need opinions/info
  173. Check Engine Light
  174. 2006 honda civic Si fg2
  175. Engine ticking or rattling noise at cold start in Reverse or Drive [solved]
  176. Valve Cover Gasket Renewal
  177. Possible engine ticking after oil change?
  178. Engine air filter
  179. 2012 Civic- weird sound after replacing air intake hose
  180. Help clearing code P0522 low oil pressure and limp mode
  181. Oil leak problem solved. Oil filter leaking bad. '07 Civic EX
  182. 2008 civic si goes into limp mode and bogs at 4000 rpm’s
  183. Codes PO300,301, 302, 303, 304, PO128
  184. Whining Sound from 2009 Honda Civic DX
  185. Rattling sound when lightly accelerating ‘09 Si
  186. *FIXED* "Whirling" sound coming from a 2015 Civic. Trying to identify/fix
  187. Code P0496
  188. Found oil leak source on 2014 Civic exl cvt. Leaking from pan. Easy fix?
  189. Being given a 2012 LX with the R18, How to syphon fuel? [solved]
  190. Car doesn't like aftermarket coils?
  191. immobilizer, no start
  192. 2010 Civic No Crank - New Starter - New Batt - One Click
  193. Burning Plastic 07 Civic Manual
  194. 2010 honda civic stalls minutes after starting
  195. Best and easiest motor swap
  196. 2006 Civic Starts for a second or two then dies immediately
  197. 1.8l JDM engines???
  198. Fuel Smell in Cabin
  199. engine won't start
  200. 2008 Civic Hybrid - fuel rail removal
  201. 2008 EX Intense Vibration Issue
  202. 2015 civic lx p0141 code
  203. engine not starting
  204. Stutters and jerks at 3100rpm
  205. 2006 civic ex 1.8 AT crank no start
  206. 9th Gen Honda civic sedan - fuel smell from exhaust on cold start
  207. Intermittent starting problems on 2015 civic
  208. Gas Mileage has decreased on 2012 Honda Civic to
  209. Misfire and low gas mileage 2014 EX
  210. Civic 2014 EX O2 Sensor Specs
  211. Cold start noise
  212. 07 Civic - Cooling fans not coming on
  213. 2014 ex hard start after sitting
  214. Possible MAF failure
  215. 2012 Honda Civic crank but won't start
  216. polyurethane front motor mount help
  217. squeak sound on cold start + bad engine mount + abs light always on
  218. i-MID oil life indicator accuracy
  219. Is "INJ" fuse for fuel injectors in 2013 Civic?
  220. Does changing battery cause rough idling?
  221. What causes white spots observed on cylinder wall
  222. 2013 Civic EX: How to get to tdc?
  223. How to tell whether spark plugs are original factory installs?
  224. Emissions System Indicator light 2012 Civic
  225. Fixing 2006 Civic muffler pipe...again
  226. Trying to identify coolant Leak
  227. tapped hole crooked into block
  228. 2014 Civic won't start
  229. 08 Civic Engine Oil Leak - Maybe this Part?
  230. 8th gen 2010 civic - not starting
  231. Piston Cooler Jet Bolt Torque
  232. Oil cooler/filter bolt? [solved]
  233. 2009 Civic EX starter not firing in the morning
  234. 2015 Civic (engine?) knocking
  235. Replacement Bolts [solved]
  236. Break-In Procedure
  237. Starter not engaging flywheel
  238. Noise at 1.000 RPM after starting The car
  239. Bad compressor & Blinking cel
  240. Shudder on Startup Which Disappears After 10Kms [solved]
  241. car dies when i press accelerator
  242. K24z7 exhaust manifold replacement
  243. Gas mileage
  244. 1.6 i-dtec - PGM-FI + Start Stop errors P166B and P049B (european car)
  245. Oil around number 2 coil pack
  246. Oil Pan loose but will not come off [solved]
  247. Engine Stalls on Slow Continuous Right hand Turns
  248. 2008 civic si 108k miles. crazy TPMS, VSA, /!\, & oil problem problem. Possible VTC
  249. My 08 civic
  250. Motor Mount Recommendation
