Check engine light auto-reset
Old Oct 22, 2025
revjj's Avatar
revjj is an unknown quantity at this point
2007 Civic LX got flooded during a bad rain storm. It flagged a CEL code of P0497 (bad purge valve) so I replaced it. Later on, as in a day or so, it threw a P2422 (bad vent valve) so I replaced that. The day after that it threw the same P2422 code so I bench tested the valves and they were good. At that point I suspected the evap canister as the flood was deep enough to submerge the entire canister. So, here is my question:
After replacing the canister, will it be necessary to reset the codes manually or will the vehicle sense that everything is A-OK and turn off the CEL automatically? I'd rather not have to go through the whole process of testing for all codes after the entire ECU has been reset.
Thank you in advance.
Old Oct 24, 2025
Colin42's Avatar
Re: Check engine light auto-reset
It takes a while for it to do the tests for evap codes.
i would just reset it with a scanner or disconnect the battery
Old Oct 24, 2025
revjj's Avatar
Does that imply that the computer readiness will ocuure faster than having to wait for only one or two evap tests?
Old Oct 24, 2025
Colin42's Avatar
It will show ready for everything but evap fairly quickly. Evap might take a week
Old Oct 24, 2025
revjj's Avatar
A week? I plan on taking it for a 30 mile trip on the highway and then 30-45 mph through the city area. Do you still think that would take a week?
Old Oct 24, 2025
Colin42's Avatar
It has to do with fuel tank levels.
Are you trying to pass an emissions test? You're typically allowed one or two not ready monitors.
Old Oct 24, 2025
revjj's Avatar
Yes, I need to pass emissions.
Old Oct 24, 2025
Colin42's Avatar
So your jurisdiction will tell you what is needed for a pass.
If you're allowed one or two not readys, reset the computer, and then drive the car with a full tank of gas until you have the bare minimum required to pass. Then bring it to the test center. Hopefully you have drive in, no appointment needed test centers. I've had several cars pass with evap issues by doing this.
Old Oct 24, 2025
revjj's Avatar
Thanks for the reply. I have yet to get the canister replaced. I'll get back when I get my findings.
EarleD
15
Feb 22, 2021 08:36 PM
EMAN64
52
Feb 29, 2020 06:08 AM
ob1ob
Jun 29, 2018 06:48 AM
BoostedTT91
23
Nov 16, 2017 10:39 AM
BrettC
Jun 21, 2016 07:53 AM
