P1129 will not go away
Old Aug 18, 2025
TrickyPanda's Avatar
TrickyPanda is an unknown quantity at this point
Hello all, I have a 07 ex with a P1129 map to high. So my issue is I cant seem to fix it. I have smoke tested it, checked wiring, check timing, adjusted the valves, replaced the trottle body, changed the map sensor 2x, and im at a lost. I have checked what it reads on reader and at idle it reads like 35ish kpa, which what i am reading is normal. I guess. I did vacuum test with a gauge the manifold pressure. looks good. I know it could be the pcm but I wanted to check if anyone else has dealt with this issue and what did you do. Thanks for your time.
inlin3
Idle Issues
Feb 27, 2023 09:49 PM
C24Creed
Sep 30, 2017 06:26 AM
Mbtech
Nov 8, 2016 09:24 AM
smoking stroker
Feb 8, 2015 10:05 PM
surfengines
Bolt-on Engine Performance
Sep 20, 2012 10:39 PM
