IAC OR IACV - Civics 8th gen 2006 EX has it or not? P0507
Old Apr 23, 2025
mreisusa's Avatar
mreisusa is an unknown quantity at this point
I got this code P0507 on my Civic EX 2006. I had previously the codes P1129 and P0497. I have an idle problem; when the car is in parking, it stays running around 1500RPM. Driving, it can stay around 1500 when I am under 50m/h, 2000RPM if I am between 50/65m/h, and above 2000RPM when over 65m/h.
I made the mistake of searching for the code and car together, and the IA (it is all IA now) keeps saying that I have a problem with the IAC. For what I found out, the 2006 EX 8th gen does not have IAC anymore. So, it has IAC or not? IAC or IACV? I almost forget that I tried the "relearn" several times, without any changes.
Any suggestions?
Old Aug 18, 2025
TrickyPanda's Avatar
TrickyPanda is an unknown quantity at this point
Re: IAC OR IACV - Civics 8th gen 2006 EX has it or not? P0507
Try doing a throttle relearn. Youtube it maybe it will help. And look for vac leaks
mreisusa
Sep 17, 2024 01:27 PM
CiViCPrAnInG2k1
Dec 10, 2004 01:02 PM
SmoOtie
Oct 20, 2004 12:04 AM
