2006 chattering relay, not starting [solved]
Old Jan 22, 2024
gizmo97's Avatar
gizmo97 is an unknown quantity at this point
Last time I used the car all was perfect
Today I went to start it and a relay under the steering wheel is chattering and the car wont start. I have about 290k on it The relay starts chattering as soon as i turn the key on on first position. Maybe a fuel pump relay? How do I find which one is that?
Thanks for your reply
Old Jan 23, 2024
BrotatoChip's Avatar
Super Moderator
re: 2006 chattering relay, not starting [solved]
Sounds more like the battery is low. Try a jump start or charge the battery.
Old Jan 23, 2024
Colin42's Avatar
This, your problem is low voltage.
Old Jan 29, 2024
gizmo97's Avatar
its not low voltage. the starter cranks rapidly. I think it might be the fuel pump. Anyone had this problem?
Old Jan 29, 2024
Colin42's Avatar
Low voltage to that relay caused by a bad connection....
Old Jan 30, 2024
Super Moderator
Chattering relays is always a low voltage issue of some kind. That would mean the starter couldn't turn the engine over quick enough or at all. Are you positive the engine is turning over at a normal starting speed? Take a video if you're not sure.
Old Feb 10, 2024
gizmo97's Avatar
im almost sure that my problem is bad ground. I found the grounding strap between the motor and chassis to be in pretty bad shape. I just ordered a new one. Some youtubers are talking about a ECU grounding around some wire harness. Anyone knows exactly where it is? How does the ECU get the ground?
Thanks ,
Old Feb 26, 2024
gizmo97's Avatar
I found the problem. The ECU is grounded by a 6 mm bolt which is located under the air box. Have to remove it to gain access. The bolt was very corroded and loose. I put a new bolt in there and vrrruuuum. Runs like new at almost 300k miles
Im very thankful to the YouTube poster
Old Feb 26, 2024
Re: 2006 chattering relay, not starting [solved]
so, low electrical power, as previously stated...
glad you got your problem solved!
montanacivic
Aug 29, 2015 03:21 PM
Ianmorrow
Feb 2, 2014 03:39 PM
em2maxamillian
Dec 4, 2012 12:10 AM
bajancivc
Oct 30, 2007 07:38 PM
VTEC01EX
Feb 5, 2003 10:37 AM
