Codes PO300,301, 302, 303, 304, PO128
Old Mar 17, 2023
Elguyo's Avatar
Elguyo is an unknown quantity at this point
2010 Civic LXS
140 K Miles
Son was driving down the free way and when accelerated vehicle lost power and felt like it was bucking and engine light started flashing. Pulled to the side of the road and shut car off and waited for a while then restarted and engine ran normal to work and home. Checked the codes and got PO300, 301, 302, 304, and PO128. No more issues reported on his way to work this AM. Car had plugs replaced within the last year or so-NGK's. Has any one experienced this and if so what has been the issue? Plan to take to my mechanic to check plugs etc. but I don't believe it is related to the ignition coils for all 4 cylinders (original coils). EGR Valve?
Old Mar 17, 2023
BrotatoChip's Avatar
Super Moderator
Re: Codes PO300,301, 302, 303, 304, PO128
P0128 is cooling system malfunction. Check coolant level is one of the first recommended steps. Coolant temp gauge working properly?
Old Mar 17, 2023
Elguyo's Avatar
Coolant low in overflow tank and a little low in radiator-topped both of them off. Thanks.
cjbess
Jul 12, 2020 11:41 AM
alex_nyc
Jun 16, 2015 01:43 PM
Jro773
Jun 9, 2015 06:38 PM
Riick
35
May 6, 2012 11:36 PM
Punkrulz
22
Feb 15, 2008 08:50 AM
