Oil cooler/filter bolt? [solved]
Old Sep 15, 2022
DaBoss1325's Avatar
DaBoss1325 is an unknown quantity at this point
What is the name of this black bolt and how much torque should be put on it? I am unable to find it in my Haynes manual. 2007 Honda Civic Si. It was removed by a machine shop when they worked on my block.
Old Sep 15, 2022
Colin42's Avatar
re: Oil cooler/filter bolt? [solved]
Tightish, filter only ever goes on by hand
Old Sep 15, 2022
DaBoss1325's Avatar
I know the filter only goes on by hand. I’m not asking about how much torque to put on the filter. I’m asking about how much torque to put on the black, 30mm bolt in the image that the oil filter screws onto and bolts the oil cooler into the block.
Old Sep 16, 2022
DaBoss1325's Avatar
Hey, it took a while for me to find it, but I finally did! The K20Z3 oil cooler bolt needs to be torqued down to 54 ft-lbs.
Old Sep 16, 2022
Re: Oil cooler/filter bolt? [solved]
https://www.civicforums.com/forums/2...ce-manual.html
Old Sep 16, 2022
Colin42's Avatar
I know you are....
Old Sep 16, 2022
DaBoss1325's Avatar
Thanks a million! I didn’t know that was there! I’ll definitely be referring to that in the future.
Old Sep 16, 2022
DaBoss1325's Avatar
I know you are....
I apologize. I didn’t mean to be rude, but I was very tired when I posted that. I appreciate the help, and I ended up finding elsewhere that it was 54 ft-lbs. Have a great one!
DaBoss1325
Sep 16, 2022 02:00 PM
Dziri
Oct 6, 2018 03:00 AM
avenger
Feb 11, 2002 07:00 PM
02Si
Jan 6, 2002 09:18 PM
