Cold start after sitting all night
Old Sep 18, 2023
Pepe10's Avatar
Pepe10 is an unknown quantity at this point
Slight hesitation with rumble first start in AM after sitting all night in 70 degree weather.After the first start and drive it starts immediately for rest of day.Any ideas?
Old Sep 18, 2023
BrotatoChip's Avatar
Super Moderator
Re: Cold start after sitting all night
Any faults?
Old Sep 19, 2023
Pepe10's Avatar
No faults/codes
Old Sep 19, 2023
Super Moderator
Possibly coolant leaking into a cylinder overnight from faulty head gasket?
Old Sep 19, 2023
Pepe10's Avatar
Coolant level has stayed normal
Old Sep 19, 2023
Colin42's Avatar
Primary o2 sensor could be on the way out, or maybe coolant temp
Old Sep 20, 2023
Pepe10's Avatar
Should have mentioned car only has 50,000 miles on it but maybe I'll multimeter test the sensors in any case.Thanks
Old Oct 5, 2023
Pepe10's Avatar
Do you think a fuel pump check valve going bad could cause this?
Old Oct 5, 2023
Super Moderator
No. I think a faulty check valve would only cause extended cranking before starting.
Old Oct 6, 2023
Pepe10's Avatar
OK Thanks for your input
gdm129
Jan 28, 2014 08:28 AM
Asblasor
Aug 23, 2012 03:40 PM
Silver2k1Dood
Aug 2, 2002 02:33 PM
NitehawkVTEC
Mar 7, 2002 12:14 AM
zackde
Mar 4, 2002 08:27 PM
