Delayed start?
Old Sep 22, 2024
dabflyboy's Avatar
dabflyboy is an unknown quantity at this point
Delayed start?
Hi all. Have 2013 Civic LX with 431,000 miles on it. After the orginal starter went bad April 2023, I replaced it with one from Autozone (Duralast 19470). It's been working well until now. Lately, I've been experiencing a significant delay in starting. When the car has been recently used (within 2 hours or so) it starts up fine. HOWEVER, if its been sitting all day or night it takes about 3 seconds to crank. What I mean is that I'll turn the key and hold it there in the start position and hear nothing for approximately 1-3 seconds (I've been counting to see if theres a trend). Then all of a sudden it roars to life like nothing ever happened. This morning, it took a good 5 seconds for anything to happen. It's a bit perplexing. Any ideas?
BTW, the battery tests good (a year old, too), all the electrical components work and appropriate cluster lights come in when the key is turned, just no immediate start as one would expect.
Old Sep 22, 2024
Nebular's Avatar
Nebular is an unknown quantity at this point
Re: Delayed start?
I just came to this forum to post practically the same issue. Mine usually is: *crank crank crank crank* quit (because I give it up). Recrank, "vroom", it starts. Starter is only a couple years old, I replaced the original because it went bad, alternator is new, battery is new. I think it has something to do with the fuel line.
Old Sep 22, 2024
FRSam's Avatar
Click Here
Re: Delayed start?
If you're still on the original fuel pump, that's probably where I'm looking next.
Old Sep 23, 2024
Nebular's Avatar
Re: Delayed start?
I suspect it. It's not enough of a problem for me to work on, but I will keep it in mind.
Old Sep 23, 2024
GolNat's Avatar
Prelude Owner
Re: Delayed start?
Cycle the key on and off a few times and see if it fires up faster (primes the system). Sounds like a weak fuel pump.
03EXHonda
Engine start problems
Sep 23, 2024 06:29 AM
Kyle Clark
Electrical
Jan 12, 2024 10:55 AM
wwhitby
Jan 28, 2022 05:38 AM
Nascarfan88
Mar 5, 2019 02:47 PM
adioskate12
May 9, 2006 11:20 PM
