Electrical Post information/questions/Issues about Electric parts here.
No crank no start - but only when cold 2010 civic
Old Jan 5, 2021
Kyle Clark's Avatar
Kyle Clark is an unknown quantity at this point
I'm having an intermittent "no crank no start" issue. I turn the key (dash lights, headlights, etc) come on, but nothing happens. With continued attempts, the car will eventually start. Sometimes it takes 3 times, sometimes 10. However, once it starts, the car starts/runs totally fine the remainder of the day. The issue only happens again the next morning or when the car sits idle for maybe 5 or is 6 hours.
I've done quite a bit of research and followed troubleshooting from various folks in this and other forums with similar issues. Battery tests are good, purchased new key from honda, ignition switch meters fine, and I've replaced the starter relay.
I have not metered or tested the starter. That's next on my list, but it doesn't seem likely given the fact that the car runs perfectly fine after the first "no crank no start" episode in the morning.
A buddy loaned me a OD2 scanner. Any chance this will give me a clue?
Would really appreciate any help.
Old Jan 5, 2021
Re: No crank no start - but only when cold 2010 civic
potentially the issue is in the wiring?
Old Jan 12, 2024
joe_stuck's Avatar
joe_stuck is an unknown quantity at this point
I am currently experiencing the exact same situation with our 2009 Civic. I'm going to stick my neck out and say that I think my issue is related to cabin temperature. Something electronic within the cabin does not like the frigid cold. I say this because once the cabin is warmed up, it never happens again. Requires frigid, saturating, overnight temps. It could be zero degrees out, but if it is sunny and the cabin warms just slightly, we will have no issue cranking.
Have you had any luck solving your situation?
Josh Phillips
Jan 12, 2018 07:45 PM
wpendl1
May 1, 2017 04:14 PM
5spdvroom
73
Jul 25, 2016 07:55 PM
dsj09b
Feb 7, 2014 03:45 PM
richs1000
Aug 15, 2010 12:14 PM
