sputtering
Old Dec 20, 2023
katfeet62a's Avatar
katfeet62a is an unknown quantity at this point
Exclamation sputtering
I have a 2013 honda civic lx coupe. Sometimes, not always, when I take off from a stop slowly the car sputters. If I give it a little more gas it stops. I bought the car about 5 months ago. When I bought it I had to replace the catalytic converter. When the check engine light came on for that the guy at o reilys said that all I needed was a $35 bottle of something in the gas. Well that was not the solution. After we installed the cat I replaced the spark plugs and gave it fuel injector cleaner. When the car is cold it doesn't do it so much. Please help me out.
Old Dec 21, 2023
Colin42's Avatar
Re: sputtering
What brand of plugs did you put in? Gapped properly?
got a scanner?
Old Dec 21, 2023
BrotatoChip's Avatar
Super Moderator
Re: sputtering
Possibilities:
-Needs new spark plugs.
-Faulty ignition coil pack.
-Dirty or faulty fuel injector.
-Low fuel pressure.
-Out of spec valve lash.
-Etc, etc....
To me, it sounds like a fuel issue. Extra fuel is added when the engine is cold.
Ron Sprinkel
Engine start problems
43
Jan 15, 2020 03:29 PM
robfarr56
Sep 8, 2017 07:53 AM
soarintothesun
21
Nov 14, 2008 02:34 PM
mndthegap1
Mar 7, 2005 10:46 PM
dazdncnfusd
Dec 5, 2002 02:55 PM
