Overheating-both hooses hot- loosing overflow coolant-heather works great
Old Nov 28, 2024
mreisusa's Avatar
mreisusa is an unknown quantity at this point
I replaced the radiator and forgot to bleed it; realized my mistake, got one of those funnels, run it (few times already), but Civic 2006 EX still overheating. Contrary of the majority of posts I read, the heater works great, both hooses up and down are getting hot, but the overflow reservoir still getting empty. I had a problem with the radiator cap, that was said to be fit for the car but was not, letting coolante spray everywhere. Changed the cap and no signal of leaking around the cap, cannot see any leaks anywhere (have to be sure it is not escaping by the reservoir cap), nor (fortunately) are the Oil or Transmission Fluid "milky" - I am finally changing next week the O-ring and gasket for the Throttle Body, as also the Spark Plugs (cannot remember if I had already changed it ir not so, lets do it). Any suggestions? Ooops, forgot to mention: the fan for the for the A/C condensor is bad (getting another one), but regular radiator works fine
wwhitby
Apr 17, 2019 01:36 PM
Vtech425
Jan 5, 2018 11:40 AM
seahorse12
Dec 3, 2013 12:49 AM
DParker
Jun 14, 2013 07:53 PM
Kernel55
16
May 15, 2011 02:18 PM
