SOLVED: Engine will not start
Old Dec 24, 2023
Edonew's Avatar
Edonew is an unknown quantity at this point
Hi! Having some issues with my car.
A Honda Civic 2008 2.2 Diesel. The problem is that it wont start. It cranks with jump cables but slowly drains when trying to start and dosent not turn over. Also the OBD Port do not connect with any OBD Scanner. This is what i have tried to fix it.
Check all fuses and relays. Battery at 14 V when trying to start. Key is recognized. Disconnected battery pole tried reset the ECU.
It all started when the DPF light came on and said Check system. Opened upp DPF Sensor and cleaned the pipes with DPF cleaner. Also added DPF cleaner in the tank. Then it died at first start then worked. The light never went away but it came out of limb mode.
- If anyone have any suggestions what the problem can be with the car? Im thinking Fuelpump do think it is a mechanical Fuelpump, or maybe a bad ECU.
Thanks in advance.
Old Dec 24, 2023
Colin42's Avatar
Re: Engine will not start
Bad battery most likely. Get it tested.
Old Dec 24, 2023
or ecu, if not connecting with reader
Old Dec 24, 2023
Edonew's Avatar
Solved: Thanks for the help! It was the Fuel cut off switch that had been triggered. A little press on it and it worked liked a charme!
2civic
May 11, 2023 08:12 PM
Amcortes10
Nov 7, 2022 08:30 AM
mopub
Aug 24, 2022 12:28 PM
Storm897
Electrical
16
Jun 24, 2021 04:45 PM
toddfiebig
Jan 19, 2016 10:20 AM
