Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
Problem with 12v Charging, seemed to go away but came back. Help.
Old Jul 1, 2021
Amcortes10's Avatar
Amcortes10 is an unknown quantity at this point
Question Problem with 12v Charging, seemed to go away but came back. Help.
Hey guys,
Initially I wasn't going to post as there was already so much information that I could find on the internet, but I'm now stumped.
-Symptoms-
  • Car runs normally up until the engine battery has less than 12 volts after that there is
    • flashing in the electronics
    • no power steering
    • shaking if it is kept driving on low volts
  • driving with the red battery light and the ima light results in
    • no assistance to the motor
    • jerky driving
-The Prior Situation-
The red battery light is on as well as the Ima light. I think it is due to the fact that the 12v is not charging. So, in doing research and learning that the 12v battery currently in the vehicle is good, I thought that the problem was in the DC-DC converter. I ordered a used one.
-The Current Situation-
After receiving the "new" DC-DC converter I put it in the vehicle. Afterwards, I turned it on and it seemed to have worked. the red battery light and the IMA light were gone. The charge of the 12v before turning the car on was 11.68 after letting it idle for a few minutes it went up to 12.68. So, the car charged the 12v like it is supposed to do. HOWEVER, after a few hours I decided to try and test drive the vehicle. As soon as I got out of the driveway the red battery light and IMA light came on just as before. So I immediately put it back in the driveway. Checking the 12v it read 11.somthing, again, not being charged by the vehicle. I tried to just turn on the vehicle and let it idle like it did before, but the lights came on as soon as I started the vehicle and it didn't charge it in idle like before.
Where could the problem lie and how come it worked for a few minutes charging the 12v only to stop??
The only code I'm getting is P1570 one stored and one pending
Thank you in advance.
Old Jul 1, 2021
Re: Problem with 12v Charging, seemed to go away but came back. Help.
could be the battery itself. consider 1 years as its life
Old Dec 13, 2021
henio81's Avatar
henio81 is an unknown quantity at this point
Originally Posted by Amcortes10
Hey guys,
-Symptoms-
    • no power steering
    • jerky driving
Hi. I have execly the same situation at the moment. Did you manage solve the problem? Thanks
Old Nov 7, 2022
raz_05's Avatar
New Member
raz_05 is an unknown quantity at this point
Hi
I am experiencing the same issue on a Honda Jazz/Fit.
Please help?
Can i bypass the hybrid system?
See attached pic of my system.
Storm897
Electrical
16
Jun 24, 2021 04:45 PM
aztecaa
Aug 29, 2019 01:11 PM
toddfiebig
Jan 19, 2016 10:20 AM
exturbo6
Aug 17, 2006 08:41 AM
