Check emmision light 2014 honda civic
Old Nov 27, 2023
lonewlf65's Avatar
lonewlf65 is an unknown quantity at this point
My check emission system light keeps coming on. I have already changed the purge valve and the canister. Light went out for about 2 weeks now came back on. Can anyone help me solve this issue?
Old Nov 28, 2023
BrotatoChip's Avatar
Super Moderator
Re: Check emmision light 2014 honda civic
What is the actual fault code? Without that, you're just throwing parts at it.
Old Dec 2, 2023
lonewlf65's Avatar
The codes I got were P0497 and P145C. Both said purge valve
Old Dec 5, 2023
Super Moderator
You will need to troubleshoot the purge valve.
Old Dec 5, 2023
lonewlf65's Avatar
And how do I trouble shoot purge valve?
Old Dec 5, 2023
Super Moderator
It is a normally closed solenoid valve. Remove and use a handheld vacuum pump/gauge to check.
Or, you can just replace it and hope for the best.
Old Dec 5, 2023
lonewlf65's Avatar
Thank you sir.. I'll try that and let you know the outcome
Sid007
Electronics
Oct 25, 2023 07:07 AM
anwarma
Electronics
Jun 15, 2019 07:56 PM
01WingsWestCivic
Mar 17, 2003 12:13 PM
ZSKCivic01
Jan 23, 2003 11:52 PM
TYPE7RS
May 10, 2002 05:53 PM
