Is "INJ" fuse for fuel injectors in 2013 Civic?
What is the "INJ" fuse in the engine compartment fuse box? The fuse is 15 A, and they put it inside parentheses: "(15 A)". What's the meaning of using parentheses? I'm trying to disable fuel injectors.
Re: Is "INJ" fuse for fuel injectors in 2013 Civic?
The little bit you'll get from doing the compression test won't make much of a difference. Pull the fuse if you're really that concerned.
taly
May 15, 2009 02:26 PM
blinger
Aug 29, 2008 08:13 PM
