What is this racket P2646
Old Oct 27, 2023
Rvpps2rocks's Avatar
Rvpps2rocks is an unknown quantity at this point
(Edit - it was rod knock, cylinder 2 spun a bearing)
So I'm new to the Honda world but I am mechanically inclined, took this off a buddies hands. Made this noise before and after oil change, was throwing a p2646 code. Changed the oil, vtec spool solenoid, cleaned the screen. And it made this noise before and after the oil change.
https://youtu.be/6jGL2pdJfU4?si=Cn5m6YRSWUMEFLT_
Old Oct 27, 2023
BrotatoChip's Avatar
Super Moderator
Re: What is this racket P2646
Sounds like a rod knock. Lots of metal flakes in the oil? Bottom end will need rebuilt or replaced.
Old Oct 27, 2023
When I pulled the vtec solenoid, there was glitter looked like steel and copper but it wasn't an abundance of it. Drain plug didn't have any glitter though
Old Oct 27, 2023
Super Moderator
Is the drain plug magnetic? OEM is not. If you empty whatever you caught the oil in there should be metal flakes/glitter on the bottom. I'm 99% sure that's a rod knock.
drhawkinz
Aug 28, 2014 09:34 PM
itsfighter
Jun 15, 2014 08:49 PM
xxslayerodxx
17
Jan 21, 2011 03:38 PM
JRHAWK9
Feb 17, 2005 02:13 PM
klam
Sep 21, 2003 02:01 PM
