2008 Civic EX - SLOW/NO START
Old Dec 5, 2023
Rchuntr's Avatar
Rchuntr is an unknown quantity at this point
I have a 2008 civic ex and am trying to figure out why it has a slow/no start. It starts to turn over but stops cranking slowly almost immediately. I replaced the body to engine and neg. cables/straps and I bought a new battery. When I hook up the battery my headlights cycle on and off steady without the key in ignition. The dash lights come on and stay on also. Any ideas on why/what is happening and how to fix? I much appreciate any responses!
Old Dec 5, 2023
Colin42's Avatar
Re: 2008 Civic EX - SLOW/NO START
Starter might be shot. Tried pulling it out and testing it?
Old Dec 5, 2023
Rchuntr's Avatar
I had the slow/no start happen a few months ago and it was a bad ground connection - so that is where I started this time. I've checked all ground and replaced Neg. battery cable and the ground strap from the body to engine block. still same issue except now my headlights are cycling on and off even without the key on or the light switch on. My dash lights are also ON but do not flash or cycle on or off. I even hooked a jumper cable from the Neg battery post to engine block with no changes. It's weird that the headlights are doing that. I'll have to check starter tomorrow. Thank you for the response!
Old Dec 6, 2023
Colin42's Avatar
That's kind of weird, see if a relay is sticking
Zajohanna
General
Nov 24, 2021 03:44 PM
PKingFire
Sep 28, 2017 07:36 PM
fletch1027
Jan 8, 2014 01:59 PM
Srikanth.chepur
Nov 23, 2010 10:57 PM
Srikanth.chepur
Air Conditioning
Nov 23, 2010 02:43 PM
