Timing Chain moving
Old Dec 30, 2020
Jay Riley's Avatar
Jay Riley is an unknown quantity at this point
Timing Chain moving
I'm rebuilding a 2010 Honda Civic LX with a 1.8L motor.
The timing chain is causing me frustration because I'm so unfamiliar with timing. I put both pulleys in the correct positions, added the chain putting the dark links over the little dot indicators on both top and both pulleys, added the guides and tensioner back. After rotating the motor a few times to work on valve lash I noticed the dark links are in the spots they started out on. I was under the impression this meant the timing chain skipped and this would be a huge issue. I've taken it apart and put it back together starting back in the right spot 5 times and the chain links keep migrating around.
The odd part is the pulleys are always in sync, they reach top dead center on cylinder 1 the same every time.
I saw a youtube video saying the chain links will migrate around using a term he called "hunting". I did an experiment with making a mark on the pulley and belt, he wanted to see how many rotations it would take to get it back to the original spot. It took 52 times around. He said it's normal.
Is it?
Old Dec 30, 2020
BrotatoChip's Avatar
Super Moderator
Re: Timing Chain moving
The timing marks on the chain will not match up with the marks on the sprockets after rotating the engine over once, completely normal. You should rotate the crank twice then verify timing marks are still at TDC, ignore the chain marks.
Now, according to my math, you should have to rotate the crank 136 times to get the marks on the chain to line back up. That's assuming there are 136 links on the chain, 46 teeth on the cam sprocket, and 23 on the crank (got the info from RockAuto).
Old Dec 1, 2023
ssbeewis's Avatar
ssbeewis is an unknown quantity at this point
2008 civic dx
hey im having the same problem i timed it properly for sure according to all the marks, when i turn it over it sounds like no compression and it backfires sometimes out exhaust, not ticking noise at all.
Old Dec 1, 2023
Super Moderator
Check your timing, make sure you got it set correctly. Any fault codes?
Old Dec 1, 2023
ssbeewis's Avatar
no fault codes detected, all timing marks line up before i put timing cover back on. wil re check timing, i think its 180 degrees out, could i just rotate crank to alignment spots then check #1 tdc valves?
Old Dec 1, 2023
Super Moderator
Depends what you mean by 180 off. 180 degrees off on the camshaft isn't possible because the crank rotates twice for every one of the camshaft. 180 off at the crank is possible but your timing marks would be nowhere close, not sure how you'd do that.
Old Dec 1, 2023
ssbeewis's Avatar
that’s what I was thinking but all bitches and dots line up but when I crank it backfires and sounds like no compression, it’s one single backfire
Old Dec 2, 2023
ssbeewis's Avatar
any other ideas or just re time and crank by hand?
Old Dec 5, 2023
Super Moderator
Your timing marks look like this?
Camshaft alignment marks.
Crankshaft alignment marks.
Old Dec 6, 2023
ssbeewis's Avatar
yes it looks exactly like this everytime I time it, cycle by hand a turn and it lines up, realized I’m low on fuel nothing on gauge, can that cause the backfiring symptom??
Old Dec 6, 2023
ssbeewis's Avatar
or is this a stretched chain issue?
Old Dec 6, 2023
Super Moderator
Maybe, put some fuel in it. You can check compression as well.
If the timing marks line up, then no it isn't.
Old Dec 6, 2023
ssbeewis's Avatar
ok will do thank you, any other ideas if not fuel??
like why would there sound like no compression?
Old Dec 6, 2023
Super Moderator
A compression check and maybe a leak-down test would tell you if the engine is healthy. Otherwise, you'd be looking for issues with spark or fuel.
Old Dec 6, 2023
ssbeewis's Avatar
ok thanks, we can eliminate spark as I’ve changed coil packs and plugs, wiring is in tact and battery is solid I’ll let you know after Friday when I have time.
Old Dec 6, 2023
Colin42's Avatar
What brand of coils?
Old Dec 6, 2023
ssbeewis's Avatar
they’re oem coils all spark tested on the ground plate on front of engine behind exhaust manifold.
Tutty6
18
Aug 31, 2017 09:37 PM
Conda Hivic
Jan 17, 2016 01:33 PM
Simpson5774
Sep 29, 2014 07:23 PM
clintonium
Oct 8, 2012 06:17 PM
Thaik
Sep 20, 2011 07:36 PM
