Oil around number 2 coil pack
Old Aug 7, 2022
melvin1942's Avatar
melvin1942 is an unknown quantity at this point
2006 Civic 1.8 lid engine. Engine missing on number two Cylinder pull coil pack and found oil on it. Bought new valve cover gasket it came with seals. Took off valve cover as it shows on you tube but there is no place for the seals to go. 1.7 has seals in the cover but 1.8 does not. do I have to put the head to fix the oil around the coil pack? Thank you for your time. Melvin1942
Old Aug 8, 2022
BrotatoChip's Avatar
Super Moderator
Re: Oil around number 2 coil pack
The only spark plug tube seals are on the ignition coil packs, and they're not designed to keep oil out. Due to the offset design, the tubes do not come up through the top of the valve cover like in older engines. If there is oil in your spark plug tube, it's like caused by a leaking valve cover gasket. Replace that first.
Old Aug 16, 2022
melvin1942's Avatar
We changed the valve cover gasket. Now we will wait and see what happens.
Thank you for your help.
Lodai
Jul 17, 2022 04:21 PM
Niko
Aug 15, 2016 10:14 PM
vdubbin95
Dec 2, 2015 01:52 PM
aplotner03
16
Aug 26, 2013 02:35 PM
civicpapi
Jan 6, 2010 07:19 PM
