2006 Civic Starts for a second or two then dies immediately
Old Jan 12, 2023
Greendesert's Avatar
Greendesert is an unknown quantity at this point
Any ideas of things I need to check?
I disconnected the fuel line where it goes into fuel rail and when key set to on it pumps fuel
I checked the EGR valve as there was a video that suggested it could be the issue. it doesn't look stuck open
I disconnected MAF sensor and tried to start. no difference.
Holding keys with slight pressure (in case maybe it's a flaky ignition switch) doesn't seem to make a difference.
I haven't really tested the relays but like I said, initially there is fuel pumped and car starts briefly
A troubleshooting diagram would be helpful, especially if it's specific to these hondas.
Old Jan 12, 2023
Colin42's Avatar
Re: 2006 Civic Starts for a second or two then dies immediately
Check engine light? Checked engine timing?
Old Jan 13, 2023
Well, right now there is no check engine light since I reset the codes but yes I forgot to mention that it has been having really bad missfires for a while and it got to where it is now, not driveable. It kept setting these types of codes P301, 302, 303,304
Oh also I replaced the spark plugs recently. I have replaced the coil packs about two years ago as it had these same kind of symptoms back then and that seemed to fix things. is it possible that the coil packs are trash again so fast?
Old Jan 13, 2023
Colin42's Avatar
If you bought crappy aftermarket coils then yes.
jmath311
Nov 25, 2016 09:27 PM
jacko290381
Sep 12, 2012 10:39 AM
Spartanic
Jun 29, 2009 09:33 PM
EM2 Bluez
Oct 19, 2006 03:41 AM
ajhdragon
Jul 31, 2005 07:42 PM
