oil filter mount replace
Old Jan 8, 2024
ngm's Avatar
ngm
ngm is an unknown quantity at this point
2012 Civic Si 135K miles leaking oil from oil filter mount after oil change. Definitely leaking from the filter mount itself, where mount joins block. Has anyone replaced this part and is there a guide with torque settings? Peace
Leaking from the joint between block and mount. could be the O-rings?
Old Jan 9, 2024
Colin42's Avatar
Re: oil filter mount replace
Probably the orings if you're positive that its not the filter or old residual oil. No idea on a torque spec, maybe 30ft/lbs
Dimm
Jul 13, 2022 10:42 AM
LoKo498
Jul 10, 2005 06:02 PM
LazyDog01
Feb 18, 2004 03:34 PM
manu
18
Aug 15, 2003 02:22 AM
Intruder
Feb 17, 2002 07:52 AM
