Engine whining sound. [solved]
Old Oct 22, 2024
Civic8545's Avatar
Civic8545 is an unknown quantity at this point
Hello, I've had this new whining sound for 3 days on my civic 2011 1.8l. Any idea of which component could most likely cause this whining? seems like it's coming from the back of the engine itself. For now, it will stop after 5 minutes of driving the car.
At 1 minute 34 seconds
https://vimeo.com/manage/videos/1022100549
If you have a clue, I would be grateful. Thanks.
Old Oct 22, 2024
re: Engine whining sound. [solved]
alternator or ac bearings?
Use screwdriver as stetoscope
Old Oct 22, 2024
Civic8545's Avatar
Ok thanks you for giving me your opinion, I will try this tomorrow morning, when I start the cold car.
I have a good screwdriver to test my alternator but the AC compressor is too low under, do you think that any metal rod could do the trick?
Old Oct 22, 2024
anything connecting your ears with the part, but keep it away from spinning parts
Old Oct 25, 2024
Civic8545's Avatar
Re: Strange scratching sound during start up
@sdaidoji
I followed your suggestion, using the stethoscope. 2 days ago the car was producing no whining, I took the opportunity to listen to my AC, Alternator and multiple point on the engine, memorized these normal sounds.
This morning it started again and I found the hot spot directly.
The rod directly over the PCV valve, on the red dot, it's coming very strong from there. Alternator and AC are normal.
Could this be a PCV valve failure sound?
(My stethoscope)
Old Oct 29, 2024
Civic8545's Avatar
SOLVED: That whining sound from the video was caused by my power steering pump, pumping air. The oil container is stained at the right level giving the impression that it's always full but the oil was a too low. A bit more oil in the container and the whining is gone, hopefully the pump was not damaged.
Old Oct 31, 2024
glad you found the issue, tons of parts there that can cause issues...
thanks for coming back to follow-up!
hnc
Suspension
Jun 4, 2020 02:36 PM
blackomen
Aug 24, 2012 11:35 AM
rileyb22
Mar 16, 2012 10:39 AM
astr033
May 10, 2004 12:27 PM
asianmatrix02
Sep 11, 2003 01:11 AM
