Whirring/whining sound when turning
Old Jun 24, 2010
hnc's Avatar
hnc
hnc is an unknown quantity at this point
I drive a 2003 automatic transmission Civic LX. Recently it has started making a whirring/whining sound. This doesn't happen immediately when I start driving, but only after I've been driving around for a little while. The sound is especially loud when I'm turning. Any ideas?
Old Jun 24, 2010
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Whirring/whining sound when turning
Noises when turning could be caused by the CV joints going out or it could just be a noisy power steering pump.
Old Jun 4, 2020
ajhondafan's Avatar
ajhondafan is an unknown quantity at this point
The symptoms you have described lead me to believe you have a leak in your power steering system, where excessive air is entering it. Power steering systems cannot have excessive air or air cavitation inside otherwise the pump can get damaged. I'm guessing the reason why your pump is whining after driving it around for a while is that air is slowly entering your system as you drive, and then gets evacuated after shutting the engine off. A good place to start diagnostics is to check your power steering fluid reservoir and ensure that the fluid is at the appropriate level.
Old Jun 4, 2020
FRSam's Avatar
Click Here
I’m assuming it’s been dealt with one way or another after 10 years
boby_turkalino
Dec 22, 2014 06:59 PM
SRCivic03
Apr 28, 2012 09:35 PM
luvnlife64
Aug 29, 2007 01:14 AM
BlueNothings
Nov 28, 2006 03:30 AM
kornsined
Engine Swaps
16
Aug 4, 2006 12:54 AM
