P1659 Civic 2013 Fixed
Old Feb 8, 2024
emich's Avatar
emich is an unknown quantity at this point
Suddenly P1659. Imposible to drive. No acceleration. Check steering Check VSA system etc.
The relay is fine. It's the one to the left closer to the door inside the car.
Under the hood fuse box a fuse between 20 and 15 Amps was missing. I put 15 A . Cleared the code. Problem solved,
Old Feb 9, 2024
Colin42's Avatar
Re: P1659 Civic 2013 Fixed
Not sure how a fuse magically disappears but at least you fixed it
Old Feb 9, 2024
emich's Avatar
It was never there to begin with.
Old Feb 9, 2024
Colin42's Avatar
So how did the car work in the first place?
Old Feb 9, 2024
emich's Avatar
I wonder the same thing. For the first time in 122 k miles I get this Code. My guess is after this code the ECU reroutes the signal through the missing fuse and the relay can not be activated.
Old Feb 9, 2024
BrotatoChip's Avatar
Super Moderator
A few other possibilities:
-It is an intermittent issue and the fault will eventually return
-The relay was faulty and stuck on (don't have the schematic to confirm this is even possible)
-Your Civic is haunted
Mattbirk
Electrical
Sep 8, 2020 06:29 AM
Justin04
Dec 18, 2017 08:40 PM
hondajordan6194
Oct 28, 2009 10:00 PM
gh0st
Lighting
May 27, 2005 10:50 AM
davemattfan5
Mar 3, 2003 09:33 AM
