Innova code reader on 04 civic
Old Dec 18, 2017
Justin04's Avatar
Justin04 is an unknown quantity at this point
Got an innova code ready for my 04 civic. And it wont connect to my car. Try 2 different of innova code reader still wont connect. Anybody else have the same problem.?
Old Dec 18, 2017
Colin42's Avatar
Re: Innova code reader on 04 civic
did you check if the fuse for the obd port is blown?
Old Dec 18, 2017
Justin04's Avatar
no i didn't and dnt know the location. Is it on the fuse box.?
Old Dec 18, 2017
Colin42's Avatar
apparently its a 10A #9 in the under hood fuse box,
looks like there's alot of different things on that circuit though, so it may not be the fuse. maybe the power wire is broken, or the pins in the connector are damaged.
Old Dec 18, 2017
What DOES the code reader say or do?
There's a huge difference between not powering up, and not being able to communicate with the PCM.
What problem are you trying to chase???
Someone forgot to tighten the alternator bolts, now the PCM is fried and only running in backup mode? Gauges acting weird?
Old Dec 18, 2017
Justin04's Avatar
Thats what the code reader is showing
Old Dec 18, 2017
Colin42's Avatar
pcm is probably fried then, check your alternator bolts, they're probably loose/stripped out. Did you recently have work done on the car that involved loosening/removing the alternator, or belts?
Old Dec 18, 2017
Justin04's Avatar
Yes i have changed the belt when i 1st got the car about 2 months ago and tighten it after a month.
Old Dec 18, 2017
How did I guess that LOL
If you want some bathroom reading, search the forum for 'loose alternator bolts' and you might get a hundred threads to look at
93IndyCivicGuy
Jan 16, 2016 09:52 PM
Scott Anderson
Apr 2, 2015 11:08 AM
Northern Civic
Mar 9, 2011 01:43 PM
sneakboxer
Mar 23, 2009 09:40 PM
MiamiUgen7
Aug 3, 2005 10:00 PM
