My civic will only start with a ELM 327 code reader plugged in.
Old Apr 1, 2015
Scott Anderson's Avatar
Scott Anderson is an unknown quantity at this point
I have an 05 Civic LX with 170,000 miles on it. It blew a head gasket and over heated. A few days latter, I was not sure if it was a head gasket so I added coolant and drove it. It ran for about a day, having to watch coolant level, but then it just wouldn't start back up.
I removed the head and had it checked, replaced the gaskets and put it back together, but it would not start. I fiddled with it for a long time, then used a ELM 327 code reader to try to figure things out, and it started. Now, if I take the ELM out it will not start. It will only start will the ELM plugged in. Any thoughts on what the problem might be?
Old Apr 1, 2015
Re: My civic will only start with a ELM 327 code reader plugged in.
Does this look familiar?
Old Apr 2, 2015
Thank you. Problem solved.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
mistermenphis22
Apr 3, 2016 08:06 AM
rcolosi
Apr 29, 2015 07:48 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
