2007 civic oil pan replacement
Old May 23, 2023
nickojb13's Avatar
nickojb13 is an unknown quantity at this point
Trying to replace the base pan on my 07. 1.8l. Everything is let go, all bolts are out and pan is loose but still unable to remove the pan from the vehicle. I’m not sure what it is catching in to cause this issue
Old May 23, 2023
Colin42's Avatar
Re: 2007 civic base pan replacement
The oil pan?
Old May 23, 2023
nickojb13's Avatar
Originally Posted by Colin42
The oil pan?
oil pan yes
Old May 23, 2023
Colin42's Avatar
The older models had a stiffner between the engine and trans that needed to be removed. Try youtube
Old May 24, 2023
BrotatoChip's Avatar
Super Moderator
Did you unbolt the A/C compressor?
Instructions:
http://civic.hondafitjazz.com/A00/HT...401KAAT00.html
77Spitfire67Mg
Dec 10, 2022 07:16 AM
JJ291
Jan 24, 2015 09:24 PM
Ray T
General 7th Gen
May 25, 2014 03:09 PM
estridge48
Jan 27, 2009 11:32 PM
bkscott
Jan 14, 2009 12:37 PM
