8th gen 2010 civic - not starting
Old Sep 22, 2022
Gefcs92's Avatar
Gefcs92 is an unknown quantity at this point
Hi looking for a bit of help. Basically ran my car to low the other day which caused it to cut out and has yet to start even after pitting 5l of fuel in afterwards. What could be the issue? I've read it could be the fuel pump/filter/air-lock etc. I'm a relative noob but could with my hands, can anyone please advise. 2010 Honda civic 129,000 miles, 1.8 petrol vvtec. Thanks
Old Sep 22, 2022
Colin42's Avatar
Re: 8th gen 2010 civic - not starting
Does it crank? Can you hear the pump prime?
Old Sep 23, 2022
Gefcs92's Avatar
yes, it's turning over fine. It even started a few times and allowed me to rev it but then died after about 2 seconds. When I turn the ignition on- not the engine- I can hear the pump prime too
Old Sep 23, 2022
Colin42's Avatar
Checked for spark?
Old Sep 23, 2022
GolNat's Avatar
Prelude Owner
If you ran it out of fuel you might have to prime it several times.
turn the key to the II position so you can hear the fuel pump come on. Then turn the key off. Turn it back to position 2 then off. Do this 5 or 6 times to get fuel to the fuel rail.
Old Sep 24, 2022
Gefcs92's Avatar
Checked for spark?
it did start a couple of times the died, I'm assuming that means it has spark?? If that doesn't please advise me how to check it does have spark. Thanks
Old Sep 24, 2022
Gefcs92's Avatar
Hi, I done this. Still no luck. What would you reccomend, thanks
Old Sep 24, 2022
FRSam's Avatar
Click Here
I'm assuming there are no check engine lights?
How often do you run the car low on fuel? You may have burned out the fuel pump.
Old Sep 25, 2022
Gefcs92's Avatar
No check engine lights and uve probably only done it once prior. I can hear the pump prime when I turn the ignition on, would it still prime if burnt out?
Old Sep 25, 2022
Colin42's Avatar
Sock might be clogged with trash
Old Sep 26, 2022
Gefcs92's Avatar
So should I install a new fuel filter?
Old Sep 26, 2022
Colin42's Avatar
You should look at it and do some diagnosis before throwing parts at it
Old Sep 28, 2022
GolNat's Avatar
Prelude Owner
I would see if I could get it to start by spraying some starter fluid down the intake. If it fires up then you know it is fuel related and you can go from there diagnosing.
eddyceez
Electronics
Apr 9, 2022 09:10 AM
giantsfan923
Jul 26, 2011 01:34 PM
trev0006
Sep 30, 2009 02:01 PM
