2006 1.8L No Crank
Old Jan 2, 2024
maverickfhs's Avatar
maverickfhs is an unknown quantity at this point
Question 2006 1.8L No Crank
When I move the key to start, no crank and nothing happens - no buzzing from ignition switch and immobilizer light is off too.
All lights show up on the cluster, battery/alternator have been tested good and starter was replaced few months back.
Could it be bad grounds causing this behavior?
Have cleaned and tightened all battery connections and grounds, so far issue has not returned again so just asking as I don't want to be stranded.
@ezone any help, please?
Old Jan 2, 2024
Colin42's Avatar
Re: 2006 1.8L No Crank
What brand of starter? Cheap aftermarket? Cleaned the connections on the starter? Checked the relay?
Old Jan 2, 2024
It was an OEM(used) starter came from a car with low mileage. Starter connections were dry and clean under the rubber boot, when starter was replaced.
Checked relays and fuses under the hood and they looked good.
Is there any specific relay(starter), can swap it with a known working one to make sure it is good too? Could it be ignition switch(no buzzing)?
Thx for the help @Colin42
Old Jan 2, 2024
Colin42's Avatar
Looked good doesnt mean anything, they need to be tested
Old Jan 2, 2024
Thx, can you please help of any particular relay that needs to be tested, then?
Old Jan 3, 2024
Colin42's Avatar
The starter relay.
Rritch01
Aug 10, 2021 10:05 AM
bluehawk91
Engine start problems
Dec 29, 2018 04:25 PM
jptra
Dec 17, 2018 07:24 PM
j_hondagirl
Nov 3, 2013 07:19 PM
vha0589
Jan 31, 2010 03:47 PM
