alternator?
Old Jan 18, 2010
vha0589's Avatar
vha0589 is an unknown quantity at this point
alternator?
ok im new to civics and this is my first one. i have my 97 sitting in the garage. i go to start there car but the batteries dead, so i jump it. i go to start the car but it doesnt crank. the radio comes on the lights come on the alarm comes on, but the engine doesnt come on. i let idle for a couple minutes and still nothing. any ideas? thanks in advance
Old Jan 18, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: alternator?
First, replace or charge the battery. Was the engine recently worked on?
Next check the starter switch located at the top of the clutch pedal. If that's fine, check whether the starter gets battery voltage on both of its terminals. if so, the starter may be bad.
Old Jan 18, 2010
CivicAK's Avatar
CivicAK is an unknown quantity at this point
Re: alternator?
do you have corroded connection? what does it do when you crank it?
Old Jan 19, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: alternator?
There is a good chance you have a bad battery, interesting that you could not jump it? If you can get it jumped, I would use a volt meter and test to see if you have 12.1 volts or so with the key on, and about about 14.1 volts running.
Old Jan 19, 2010
dnice78's Avatar
dnice78 is an unknown quantity at this point
Re: alternator?
If you can do a load test on it that would be the way to go. Load test, then if battery is good test alt.
Old Jan 21, 2010
vha0589's Avatar
Re: alternator?
when i crank it nothing happens at all. the terminals arnt corroded and i brought the battery to autozone they said it was good. so i guess i should try a load test. thanks guys for the advice
Old Jan 21, 2010
civicpapi's Avatar
Re: alternator?
Are you the owner? Does it have a starter kill on it? have you turned off the alarm?
If you try to crank and no noise nothing, might be an alarm issue.
Old Jan 21, 2010
vha0589's Avatar
Re: alternator?
yeah its my cousins car.he's storing it in a garage and im lookin after it. we'll when i jumped the car it didnt crank, the alarm came on but it wouldnt respond to the alarm remote. so i dunno mangs. thanks
Old Jan 22, 2010
dnice78's Avatar
Re: alternator?
battery in remote good?
Old Jan 24, 2010
vha0589's Avatar
Re: alternator?
yeah it works. like when it went off i went to turn it off, it shows that im trying to turn it off. but nothing happens. theres prolly something wrong with the alarm, but i dunno.
Old Jan 24, 2010
civicpapi's Avatar
Re: alternator?
Does it have a honda alarm or aftermarket alarm?
Old Jan 30, 2010
vha0589's Avatar
Re: alternator?
compustar aftermarket
Old Jan 31, 2010
dnice78's Avatar
Re: alternator?
hmmm... is the factory alarm system unpluged? I think its the grren harness behind the cup holders.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bonobo
Oct 2, 2015 06:58 PM
ken4444
Sep 30, 2015 07:37 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Bricoleur
Sep 9, 2015 12:23 PM
