P0304 misfire ?
P0304 misfire ?
Sup guys just a quick question if anyone can help out. I have a 2009 civic v4.
Out of nowhere car went into limp mode
VSA and CEL light came on.
Scanned the car and it threw P0304 misfire.
(Misfire on cylinder 4)
I tried unplugging the coil packs one by one to test it.
Correct me if I’m wrong but, when u disconnect the coil pack from cylinder that’s misfiring, there shouldn’t be any change right?
When I unplugged cylinder 1&4, the car stalls.
When I unplugged 2&3, the car runs fine.
Is that normal ?
Just wanted to check in before buying new spark plugs and coil packs.
Is that normal ?
Re: P0304 misfire ?
Try swapping the coil packs around to see if the code moves.
unplugging the misfiring one should make no difference.
Weird that #1 is doing the same.
get denso plugs and coils
Emerica475
Dec 26, 2008 12:52 AM
nismostreets21
May 11, 2006 01:48 PM
