Check engine light problem!! HELP
Old Dec 24, 2008
Emerica475's Avatar
Emerica475 is an unknown quantity at this point
K heres what happened i had second cylinder misfire so i swithched coil packs around and got 4th cylinder misfire so i replaced the coil pack and now a few days later the light came on again with cylinders 1-4 misfire i also have all new spark plugs........ so any help would be greatly appreciated
Old Dec 26, 2008
cim's Avatar
cim
cim is an unknown quantity at this point
Re: Check engine light problem!! HELP
Are you getting all cylinders misfire? I would check fuel pressure and injectors. Do you have the freeze frame data on the misfire DTC?
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
