Misfire Cylinder 4
Old Dec 13, 2019
civicjames24's Avatar
civicjames24 is an unknown quantity at this point
Misfire Cylinder 4
I currently own a 2007 1.8 Civic.
I was driving to the local shop on Sunday and had no issues. I went in the shop, done a bit of shopping and came out, and my car was limp. Had no power and the engine management light came on as well as the VSA.
Spoke to a mechanic friend who suggested it was the coil pack. Checked by running the engine and unplugging each one listening for a change in the engine note. Cylinders 1,2 and 3 all had a drop but cylinder 4 had no change in the note. Changed that coil pack and all 4 spark plugs for good measure. Started the engine and the light came back on. Plugged into a code reader to try and switch the light off however was still reading misfire cylinder 4. Swapped the new coil pack to cylinder 3 to check I had not bought a bad coil pack. Still the same cylinder 4 misfire.
I am now stuck as where else to look into this. What seemed as an initial easy fix has snowballed and now I'm unsure what to do? Has anyone experienced this fault?
Thanks in advance.
Old Dec 13, 2019
BrotatoChip's Avatar
Super Moderator
Re: Misfire Cylinder 4
You really only need three things for combustion: compression, fuel, and spark. You replaced the spark plug and coil but you still need to make sure they're actually producing a spark. Two other things to check after that still.
Old Dec 16, 2019
Hello, can confirm they are producing spark and also had the car hooked up to a compression tester last night. No issues with compression either. Looking at swapping the injectors round tonight see if that could be the cause.
Sarahg9106
General DIY
Jan 15, 2013 09:04 AM
6strngs
Nov 26, 2010 07:08 AM
97 Civic coupe
Sep 27, 2010 09:13 PM
fondahonda
Sep 6, 2006 06:18 PM
nismostreets21
May 11, 2006 01:48 PM
