PDA
View Full Version : Engine
Pages : 1 [2] 3
  1. rpm drops when a/c is switched on and automatic transmission gear put in Drive mode.
  2. 2009 Honda Civic starts runs drives shuts off then starts again.
  3. Oil Leak Honda Civic LX
  4. P1129 code
  5. Quick Questions regarding spark plugs 2015 Civic SE
  6. Civic making weird noises
  7. '07 Si Engine Block Cracked and Head Gasket Blown
  8. P1077 code
  9. Do I Need to Replace Bad Engine Mount?
  10. 2010 Civic LX terrible gas mileage 22mpg
  11. Head gasket
  12. Swapping engines 1.8l - crankshaft position sensor question [solved]
  13. 2012 1.8l engine removal from top - need advice! [solved - possible]
  14. 2015 won't start [solved]
  15. Longer cranking when warm
  16. Source of water in oil? 09 SI K20Z
  17. 06 civic ex coupe. Help please.
  18. Excessive fuel consumption?
  19. Starter Issues
  20. Radiator fan and additional issues
  21. Blown 2010 honda civic swap with 2012 honda civic 1.8 issues !!!
  22. 07 civic vs 12-15 civic
  23. Another jerk issue [solved]
  24. 2015 Civic EX CVT [solved]
  25. weird noise in the engine
  26. Busted off piece of the block while removing the timing chain cover. Any hope?
  27. 2013 Honda Civic starting problems [solved]
  28. 2006 Honda Civic Multiple Cylinder Misfire & Coolant Disappearing
  29. Car does not start, neither cranks
  30. No start after cvt replacement 2014 Civic
  31. Loss of mileage
  32. Chassie - error code P0135
  33. Jerking and axel
  34. 2012 Honda Civic Lx Starter Relay diagram??
  35. Engine making a noise
  36. Should I be worried about this?
  37. Rattling noise on cold start up
  38. 09 Civic do not start
  39. 2008 Civic Si part indentification help
  40. 2012 lx throwing p0128
  41. 2007 Honda Civic Stalling and black smoke
  42. Car vibrates at red lights
  43. 2014 Civic LX intermittent starting issue
  44. Constant vibration noise coming from the engine.
  45. Fuel Pump Relay??
  46. 8th Gen Honda Civic Sparkplug change 1.4L UK Model
  47. 2015 EX civic Stalling when accelerationg from stop 0mph
  48. Leaking Coolant Drivers side
  49. Muffller broken 2015 honda civic
  50. Engine Rattling in 09 Civic
  51. In VERY cold weather, car cranks great but does not start
  52. Best Fuel Cleaners?
  53. Best Way to Check the Coolant Tank level in a Civic 2013
  54. 2014 Civic EX 1.8L CVT Oil Leak
  55. 2006 Civic EX
  56. 2012 Honda Civic Coupe - Damaged Oil Pan
  57. Engine temperature high warning
  58. Does anybody know the oil pump mounting bolts spec?
  59. 07 civic hybrid consuming a lot of fuel
  60. Car maybe running rich. Take it in for diagnostics?
  61. Rough Idling
  62. Radiator adapter info
  63. civic ctdi 2.2 diesel cant accelerate after 15minute journeys,cant rev past 1200-1500
  64. Is this the intake breather hose?
  65. FN2 Cranks But Not Starting
  66. 2013 si engine chugging
  67. P0171 code MAF sensor code on 2015 si
  68. Crankshaft seal removal
  69. New here, Need help! 2012 Civic
  70. Honda Civic 2007 1.4 Petrol EU Version O2 Sensor Location
  71. 2006 civic will not start and no power to ignition relay
  72. 2015 1.8 Hesitating from stop upon acceleration.
  73. Looking for a good locking gas cap
  74. 08 Civic consume lot of fuel
  75. Light stutter parked in D, and between 80-90 kmm/hr
  76. How to tighten Crank Pulley Bolt w/o Honda Special Tool
  77. Start-up issue [solved]
  78. New head and gasket now no oil pressure
  79. 09 Civic - Flashing Dashboard Lights
  80. Idling issue - please read!
  81. Grinding noise
  82. 2015 civic si random misfire
  83. Car does not crank
  84. EPS, VSA, engine light and fault codes P0087 & P0546
  85. 2015 fuel feed hose chewed by rodent
  86. 2007 civic hybrid poor MPG
  87. Starter removal
  88. Help identifying part [solved]
  89. 2006 Civic Will Not Start
  90. 2012 Honda Civic LX TRANSMISSION problems
  91. 2010 Honda Civic AC suddenly stopped working and cars making clinking sound
  92. 2012 Honda Civic Spark Plugs
  93. Rough idle/electrical issues after 12volt replacement
  94. 07 honda civic crank no start
  95. Rough Idle When AC is OFF
  96. Civic 08 starts up and weakly idles and dies or if I give it gas.
  97. Engine rattling when accelerating
  98. Engine Light
  99. Lower torque Motor mount help please!!!!
  100. Won't start
  101. Front passenger motor mount bolt help and where can I buy??
  102. Smog check and clearing a code
  103. 2011 honda civic 4 dr sedan
  104. Differences between R16a1 and R16a2 engines
  105. 2012 LX 5 spd manual hesitation, stuttering [solved]
  106. 2007 civic si smoke pouring out from underhood
  107. Civic FD, Fuel pump drop to 9.30 vdc
  108. 2007 honda civic wont rev past 3500 rpm
  109. Where is vacuum Hose for GDI intake valve clean
  110. 2012 honda civic 1.8l stalling problem
  111. civic fn1 i-vtec spool valve solenoid - manual test check help?
  112. Car shutting off issue
  113. 2009 Honda Civic - High Pitch whine
  114. 2014 civic ex Catalytic converter
  115. 2006 civic cylinder 1 misfire
  116. SI 8th gen rod knock?
  117. Question p0118 temp sensor
  118. 2007 civic si coupe
  119. Fuel pressure relief
  120. Originan 02 sensor
  121. Temp sensor question
  122. New to forum and CIVICS
  123. Wierd sounds while turning the steering
  124. 2008 1.8 Serp belt tensioner broke bolt [solved]
  125. Honda civic 2013 sometimes cranks but won't start
  126. Need to replace Knock sensor r18a1 2007 civic lx
  127. Help please., New Thermostat not opening
  128. 2015 9th Gen Civic Crank Position Sensor CKP or Cam Sensor 1.8L
  129. Couple problems with my car
  130. Car buzzing upon start and gas pedal pressed
  131. 2011 Honda Civic 1.8 sedan jolting around 50mph
  132. Need help diagnosing. 2013 civic lx
  133. 09 Civic sedan Thermostat ?
  134. Belt Tensioner Leaking - 2013 Civic
  135. Rough idle after engine is warm
  136. Continuous misfire
  137. Valve adjustment necessary?
  138. 08 lx sedan civic losing power “jumping” after vtec gasket replacement at 3000+ rpm
  139. Sudden drop in MPG
  140. Civic 2012 1.8L high fuel trims at idle
  141. 2009 Civic whining sound from serpentine belt area
  142. Take to long to reach normal idle during cold start.
  143. Coolant pipe name?
  144. 2013 1.6 i-dtec ticking noise
  145. Rpm surge issues nightmare (videos)
  146. RPM surge
  147. 2006 EX, slow to warm up
  148. Running rich with or without CAI. Excuses running out...
  149. Flashing check engine light
  150. Engine loses power at 2600-3000 rpm especially going up hills P1861
  151. New head gasket
  152. What is this cap/plug?
  153. RPm dropping issue in civic exi 2006
  154. 2010 LX Poor Gas Mileage
  155. 2010 EX sedan rough idle mystery... [solved]
  156. high rpm coasting civic si
  157. 2012 Civic LX Automatic Noise
  158. water squirking/weird noise
  159. 2011 Civic LX Pings in cold weather
  160. Civic 2006 oil leak
  161. Just received a gift 2009 civic but
  162. 2012 EX, Rattle in Reverse with AC on [solved]
  163. 2007 civic lx
  164. 06 EX Water Outlet Leak
  165. start problem
  166. Check engine icon on Civic 2008
  167. Not sure what these holes are for?
  168. Coolant leak!!
  169. Timing Chain moving
  170. 2010 Honda Civic LX 1.8l Head Bolt pattern and torque
  171. Honda Civic LX 2010
  172. Black piece broken, oil collecting?
  173. misfire
  174. Whining noise from engine at speed
  175. 06 civic fails to catch.
  176. 2012 Honda Civic Hybrid will not start. Cranks once. Not seized
  177. Dreaded P2647 vtec code
  178. 2012 Civic LX vibrates on cold start
  179. fan not turning on
  180. 2010 CIVIC 1.8 wont start + flashing dash
  181. Is this a normal temperature range?
  182. 2012 Civic Si Exhaust Sounds like a Diesel (Video Included)
  183. 8th Gen (2007) CIVIC
  184. 2015 Civic - VIDEO engine rattle (tensioner?) on cold start
  185. 2015 Civic LX Hesitation/Jerking PROBLEM SOLVED!!!
  186. R18 rocker arm assembly
  187. Ecu p2647
  188. throwing good money after bad
  189. 2012 civic lx Vibrations and hesitation
  190. 2014 Civic ran out of oil
  191. 2007 civic LX Weird rattle/rumble on low rpm
  192. 06 Civic w/ P0172 and P2A00 codes
  193. 2011 civic check fuel cap
  194. 8th and 9th gen exhaust
  195. p1129 and high idle and poor gas mileage (18 MPG) aftr engine replacement
  196. Replaced Honda Civic mount but caused more vibration?
  197. 2010 Civic Hybrid Valve Adjustment
  198. please help!! 2008 civic hybrid knocking
  199. Car shudders
  200. 08 si orig owner 195000 mi perfectly maintained
  201. Identify mystery part
  202. Leak at the cover breather
  203. Ignition coil
  204. Crazy noise when accelerating! Video
  205. Help/suggestions with hesitations and misfires
  206. K24Z7 2012 Civic SI VTC Issue
  207. 2013 Honda Civic won't start sometimes!
  208. IAT Sensor
  209. No start, no crank, one click
  210. 2009 civic hybrid right engine mount noise
  211. Direct injection hondas and intake valve carbon build up
  212. Car acts like it’s running out of gas
  213. Honda civic 8th gen rough idle / overheating / maybe leaking turbo
  214. Valve adjustment feeler gauge
  215. Pressure sound voice from engine after turning off
  216. 2013 Honda Civic starting isuues (sometimes)
  217. P0304 cleared and won't start now
  218. 2009 honda civic coupe not starting
  219. 2006 Honda Civic 1.8l oil in my spark plug tube
  220. 2008 HCH starting weirdness
  221. I know nothing about cars, please help!!
  222. Hond Civic dtc error - help
  223. What to do next?
  224. 2008 Hybrid Starting Issue
  225. Weird noise
  226. 06 Civic Started Making Loud Noise
  227. Spark plug gap size
  228. Idle problem
  229. engine light
  230. Honda civic ex dying at stop?
  231. 07 civic hybrid P0420 code?
  232. 2013 Civic LX hesitation issues
  233. Help
  234. Engine fluid leak
  235. P2185 code 2011 civic lx
  236. 2012 civic 1.8 misses at 1500RPM
  237. 2007 Civic SI ticking noise
  238. 2008 Honda Civic Temp Gauge Issues
  239. 09 civic ex - CRAZY HUM AND VIBRATION
  240. Starter issue
  241. valve adjusting should I?
  242. 08 Not starting after battery replacement
  243. Acceleration problem
  244. please help no start!!!
  245. Fuel filter on 2015 Honda Civic Hatchback
  246. Terrible fuel consumption in 2009 honda civic dx
  247. 09 Civic PVC valve
  248. 2007 Civic P0304 Misfire & No Power
  249. Oil leak just below or near idler pulley
  250. Honda Civic FD4 1.6L ECU error code
