2012 Honda Civic Lx Starter Relay diagram??
Old Apr 13, 2022
TheHondaMama's Avatar
TheHondaMama is an unknown quantity at this point
I need some serious help trying to fix
my little mama Honda before these boys try to tear out and replace the starter because the “think” that’s it. I heard it could simply be the relay fuse but I can’t find which on it is exactly because my fuse box looks different then others for some odd reason. My car was working fine then when I got into the car to turn the key it stops after one click. Already checked the battery which is fine they said at the Dealership.
It doesn’t do the “click click click” as normal, it just clicks ONCE then nothing. Can someone help me to find my relay so I can try that before they start taking out major parts!!! Please help me!!!
Old Apr 13, 2022
FRSam's Avatar
Click Here
Re: 2012 Honda Civic Lx Starter Relay diagram??
Looks to be fuse 5 (7.5A) in the fuse panel in the engine bay.
Old Apr 13, 2022
So that doesn’t tell me where the relay is just
the fuses or did I miss that part
Old Apr 13, 2022
I need to know if it’s R1 R2 R3
Old Apr 13, 2022
I already changed that one but I need the relay location
Old Apr 13, 2022
BrotatoChip's Avatar
Super Moderator
I only have a manual for the '06 so it may differ. It shows a relay in the under-dash box. It would be labeled.
Old Aug 2, 2022
Blue88mule's Avatar
Blue88mule is an unknown quantity at this point
Did you ever figure out anything with the relay or where it was located? I have run into the same problem and i can't find any information that is helpful.
Old May 9, 2025
LilyMica0819's Avatar
LilyMica0819 is an unknown quantity at this point
Did you ever find out the answer to this? I have the same problem.
2000 Civic EM1
Electrical DIY
Oct 30, 2021 09:20 PM
Alfred Hill
21
Nov 12, 2016 01:24 PM
medo
May 6, 2016 01:40 PM
Davmat
Mar 13, 2014 10:28 PM
01rpst
Mar 8, 2005 07:51 PM
