weird noise in the engine
Old Apr 30, 2022
weaselboogie's Avatar
weaselboogie is an unknown quantity at this point
This almost sounds like its coming from around the pulleys on the serpentine belt. It doenst happen all the time and doesnt seem to effect the driving.
Old May 1, 2022
GolNat's Avatar
Prelude Owner
Re: weird noise in the engine
Does it get louder/more frequent as the RPM’s increase?
Old May 1, 2022
No. Its very infrequent. In fact, I dont think I can even hear it when I'm driving. Just idling.
Old May 2, 2022
BrotatoChip's Avatar
Super Moderator
Sounds like a bad bearing to me. Now, which pulley? You could try removing the belt then spinning each by hand. See if you can feel anything.
Old May 3, 2022
You're correct! Turns out I had 2 bearings going bad. I just replaced the water pump because it had a little play and the noise was still kinda there. The tensioner pulley is the pulley thats still making the noise. Can I JUST replace the pulley or do I need to replace the entire arm?
Old May 3, 2022
Colin42's Avatar
You can, however the spring mechanism in the tensioner is probably worn out
bumbico
Dec 20, 2020 01:13 PM
topaz
Nov 11, 2017 11:32 AM
ShadowDaisy82
16
Nov 9, 2017 02:11 AM
bokogabe
May 21, 2015 09:27 PM
nsrhonda89
Jan 1, 2014 06:06 PM
