2015 Civic LX Hesitation/Jerking PROBLEM SOLVED!!!
Old Oct 19, 2020
christinalowe34's Avatar
christinalowe34 is an unknown quantity at this point
When accelerating from a stop or slow speed, car would hesitate/jerk. No CEL or warning lights. Mechanic was moving stuff around in engine and found a tear in the intake boot. In order to see the tear, he had to squeeze the boot. The crack was in one of the creases. I attached a picture of the part
Old Oct 20, 2020
CraigW's Avatar
Re: 2015 Civic LX Hesitation/Jerking PROBLEM SOLVED!!!
Thanks for info !!
Old Mar 29, 2023
MyHondaLuck's Avatar
MyHondaLuck is an unknown quantity at this point
Replacing this boot does nothing for fixing the hesitation. It is however a known part that needs to be replaced every few years due to poor quality rubber used.
Old Mar 29, 2023
Colin42's Avatar
It did for this person. You may have a different problem.
Old Dec 20, 2023
katfeet62a's Avatar
katfeet62a is an unknown quantity at this point
I have a 2013 honda civic lx coupe. It kind of sputters when taking off slowly from a stop but when I give it a little gas it stops. Any ideas. Just had fluids checked, filter changed, fuel intake cleaner and some other stuff O rielys sold me because my check engine light came on saying it had something to do with the cat, it was the cat.
Old Dec 21, 2023
Colin42's Avatar
Don't listen to anything orieleys says
Old Apr 19, 2025
Rob Jones12's Avatar
Rob Jones12 is an unknown quantity at this point
Hi there
I have exactly the same issue and I have done so many things but none seem to fix this issue. Wondering if you are able find and rectify this annoying issue.
Bamiller91
General 8th & 9th Gen
Jul 2, 2018 03:22 PM
MPG
Feb 5, 2018 12:55 AM
Zachlee
Jul 3, 2017 09:06 PM
