2012 Honda Civic LX TRANSMISSION problems
Old Aug 4, 2021
semaj's Avatar
semaj is an unknown quantity at this point
Hey my Honda seems to be having some problems when accelerating, it is slow acceleration unless I really push it into the 4-5k rpm range.
When getting on the freeway it seems like in 4th gear going to 5th gear (I think) the speed gets stuck and rpm will go higher but my speed will remain the same unless I briefly let go of the gas pedal for a second.
Car drinks about a quart of oil every 1-2 weeks
2012 Honda Civic LX 4 Cylinders 1.8L
151k miles
no mods, all stock.
purchased 2014 and it had 40k miles on it
I only have replaced brakes, tires, oil changes, and 1 transmission fluid change, no other work has been done.
I have transmission fluid, radiator fluid, brake fluid all at good levels. ac/heater works good.
Old Aug 5, 2021
Re: 2012 Honda Civic LX TRANSMISSION problems
air filter? spark plugs?
Old Aug 5, 2021
BrotatoChip's Avatar
Super Moderator
Leaking or burning? That's an unhealthy amount unless you're putting on 1k+ plus miles in the same time frame.
Old Aug 5, 2021
semaj's Avatar
air filter should be ok, I am unsure about the spark plugs...
Old Aug 5, 2021
semaj's Avatar
I do not notice any leaking going on
Tildon
Transmission
May 3, 2020 08:03 PM
minghos
Jul 10, 2018 11:32 AM
hishorselover
Nov 4, 2016 01:15 PM
OhioIsOnFire1
Nov 23, 2013 09:26 PM
itsfighter
Transmission
Jun 19, 2011 03:23 PM
