2012 Honda Civic LX Transmission Issue
Rep Power: 0 2012 Honda Civic LX Transmission Issue
My 2012 Honda Civic LX has a problem with its transmission, and I was hoping to reach out to the community for advice on how to fix this. SO basically when I drive, the car starts to shake/tremble from side to side and as I keep driving, the shaking eventually goes away. Do you think there is a faulty part I should have replaced, or is there any other advice I can take to have this problem fixed? Please let me know. Thanks.
Re: 2012 Honda Civic LX Transmission Issue
TCC shudder. You've never bothered to properly service the transmission? Do a fluid service NOW with Hondas DW1 fluid.
Check service manual for ATF fluid change procedure. On older Honda's it's recommended drain and fill only (no machine flushing). I'm not sure about the procedure for a 2012..Ezone most likely knows though.
OP: TCC shudder explained http://www.agcoauto.com/content/news/p2_articleid/203
Allow me to add some info
In the early stages of the problem, Hondas can exhibit the shudder much less violently than described in the article, and at a wider range of speeds than the article states because most Hondas that can have the issue can apply the TCC in all forward gears. A common condition for the shudder to occur is shortly after a light throttle gear change, say from gears 2-3 or 3-4, but it can happen at other times too.
I've heard the severity of the shudder described as "did you feel that too, or did I imagine that?", and "jiggling my jowls" (my favorite), and all the way up to "shaking the the dashboard up and down".
The TCC issue can also present itself as a slow repeating slip-stick condition, which may be seen as the tach needle bouncing slightly as the engine RPM changes by 50-200 or so, and without the shudder vibration.
In published literature it's written as "strongly discouraged".
Our procedure is still simply drain it and fill it.
Once for a basic fluid service; thrice or four times if the fluid is severely neglected, deteriorated, or contaminated.
Use of correct Honda DW-1 fluid is also critical, and mandatory for all model year 2011 and newer A/T.
If the problem is ignored long enough, it might end up needing more than just simple fluid services to solve the problem.
Sometimes a clogged or faulty EGR valve or clogged EGR ports can cause a shudder trying to maintain a constant speed and can mimic transmission shifting issues FWIW.
OhioIsOnFire1
11-23-2013 09:26 PM
